![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 RS Inferno Orange Metallic Join Date: Mar 2010
Blown head Gasket
Car went in for water leak, just got information back
Blown Head gasket Car had 97,000 miles on it. don't know if we are going to park it or fix it yet. |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 2SS/RS M6 Join Date: Oct 2015
![]() Drives: 2012 Camaro RS 2LT 6spd man Join Date: Aug 2013
I don't think the V6's are with the overhead cams. If his is a 6?
Ret AF, cancer survivor
Drives: 2013 Camaro 2SS/RS & 2006 Corvette Join Date: Jul 2015
In his signature he indicates he has an RS; if so, he doesn't have an LS engine
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Miss Con Ception Join Date: Aug 2016
It's almost always worth it
The car is worthless without it.
What will it cost and how much longer do you plan to drive it? We had one done on a Grand-Am and it lasted the rest of it's life.
2011 1SS/RS LS3 CGM
#6 |
![]() Drives: 2015 Camaro 2SS Join Date: Oct 2016
If you leave it with water sat in it, you might as well scrap it now.
#7 |
Looking at getting it fixed
Gaskets, chains water pump About 4300 If I go with new engine 6500 but I get 3 year warrenty |
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: LT W/2LT,blue metallic Join Date: Jul 2016
as nice as that car is i think id want the whole engine.
#9 |
#10 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
Had my head gasket and timing chain replaced for about $2800. About 146k on the Odometer at the time.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ |
#11 |
Drives: Camaro V6 Join Date: Oct 2016
