Old 02-10-2019, 12:17 AM   #1
0-120
Drives: 2014 Camaro SS LS3
Grinding on 1-2, occasionally 3-4 under WOT
When I am pushing her hard, the trans grinds sometimes from 1-2 and rarely 2-3. Is this a sign of clutch starting to go? I know for certain I have the pedal pushed down. Once I had to press the clutch twice to get it into second.
416HP, 422TQ. Rotofab CAI, Dyno Tuned. ALP's and a V1.
0-120 is offline   Reply With Quote
Old 02-10-2019, 09:40 AM   #2
Lonewolf583
Apex Predator
Lonewolf583's Avatar
Drives: 2010 2SS/RS M6 Rally Yellow
This happens to me sometimes...I wonder if I need to bleed the clutch. Mine's a 2010 and it got a new trans in 2013 (snapped my output shaft like some other early cars have experienced)
2010 Camaro 2SS/RS - LS3/TR6060, Paid Off \o/
Beating physics into submission since 1991.
Lonewolf583 is offline   Reply With Quote
Old 02-10-2019, 10:21 PM   #3
0-120
How would bleeding it resolve this? I am increasingly concerned because I don't want to drive off somewhere far and lose the clutch. Problem is that I bought it used, so I have no idea when it was last replaced (if ever). I'm wondering if I should just preemptively replace it.
Old 02-10-2019, 11:55 PM   #4
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 SW 2LT/RS LFX/AY6
I would try bleeding your clutch / replacing the fluid and changing your transmission fluid and going from there. There are a lot of options for fluids that SS guys like to run.
DSX_Camaro is offline   Reply With Quote
Old 02-11-2019, 12:20 AM   #5
0-120
Clutch was bled in October 2018. Transmission fluid replaced in November 2018.
I have already tried the fluids
Old 02-11-2019, 01:51 PM   #6
DSX_Camaro
DSX_Camaro's Avatar
Hm. That's unfortunate. My next thought would be to upgrade to the Ideal Garage master cylinder for your clutch (which frankly I would do if you swap your clutch too). But it does sound like your clutch is dying.
Now that said to my knowledge if you aren't racing or anything it seems like the clutches in these cars don't just "go". It'll just keep getting worse. Both my stock and my previous twin disc clutch would drive "okay" at the end of their life but it was obvious they would slip under low rpm high load or just taking off and caused me to grind 2nd and 3rd maybe a half dozen times total.
Old 02-11-2019, 04:35 PM   #7
0-120
Thank you for the information. If that's the case, maybe I'll venture across the country again. Seems like I would have enough warning if things got really bad to plan a repair.
I can't find the master cylinder you mention.
Old 02-11-2019, 05:46 PM   #8
DSX_Camaro
DSX_Camaro's Avatar
I guess IdealG doesn't exist anymore. That is also unfortunate. But yeah, I definitely think you don't have to worry about it yet. Depending on how much you drive it could very well be this year though. Once you get uncomfortable with it, swap it.
Old 02-13-2019, 07:53 PM   #9
V8only
Drives: 2012 camaro 45th 2ss/rs Centri SC
you have a 14? You shouldn't be having those issues, as they were using the carbon fiber synchros by then. My suggestion is to make sure you have a remote reservoir for the clutch, bleed it again, and consider swapping in a stainless clutch line and master cylinder from tick...if that doesn't fix it then you're looking at a synchro job for the trans
Jeremy
-2012 Camaro SS 45th M6-Kraftwerks Supercharger
-2003 Avalanche z71-6" on 35's. DD 290k miles
-66 mustang fuel injected resto-mod
V8only is offline   Reply With Quote
Old 02-17-2019, 08:11 AM   #10
WhiteOut_1LE
Drives: 2015 Camaro 2SS/RS 1LE
Its your synchros , im going thru the same issue with a 2015 1le . The Tremec6060 is know to have this problem. Swapped out fluid and changed clutch same issue. Ordering full carbon fiber rings soon !
2015 Camaro 2SS/RS 1LE - LSX376-B8, Eforce-1598 Supercharger, N20 Dual Stage kit , ARH Headers and CatBack , Willwood Big Brake Kit ,BMR subframe connectors, AFe Rear subframe bushing , AFe PFADT Tie rods and Trailing arms, and MRR z28 Replicas 20x10s and 20x11s - Toyo ST ii 285/30/20 - 315/30/20
WhiteOut_1LE is offline   Reply With Quote
Old 02-17-2019, 12:45 PM   #11
V8only
White out- your car came from the factory with carbon fiber Synchros. e They shouldn't be worn. If they are you should be examining all your hydraulic components as something caused then to wear prematurely. All came with carbon Synchros.
Jeremy
Old 02-17-2019, 02:05 PM   #12
George-CZ
George-CZ's Avatar
Drives: 2010 2SS LS3 and 1978 STROKER 383
If you do not know if there is a clutch or synchronization problem, check it out by double-tapping the clutch.
Like in a truck without synchronization.
If you can shift without gringing, is a problem with sanyronization.
If the problem persists, is a problem in the clutch.
George-CZ is offline   Reply With Quote
