02-10-2019, 11:05 AM | #1 |
Drives: 2011 Camaro RS Convertible Join Date: Feb 2019
Agressive Stance- Old School Rake?
When I was a teenager I simply put air shocks under the back of my hot rod to produce the forward leaning incline that I wanted.
Can this be done to the Gen 5? I really don't want to lower the front but I would like to see that back end lifted for that nostalgic look that I remember. Ideas? Photos? I would love to see and hear your thoughts. |
02-10-2019, 11:29 AM | #2 | |
Going places
Drives: 2011 2LT/RS Victory Red Join Date: Oct 2010
"just stay with traffic, you'll be fine". = famous last words |
02-10-2019, 11:51 AM | #3 |
How much would you want to raise the rear?
The Camaro uses a normal shock in the rear, so you could probably get an air shock in there, however ride quality might suffer a bit. Unlike the old school cars that had a solid axle, if you were to utilize air shocks in the rear, it would probably necessitate some changes to the rear alignment since it is an IRS car or you could end up with accelerated tire wear issues. This would also require you to monitor the air pretty regularly to ensure ride height is consistent. A new set of coil springs that raise the back end 1, 1-1/2", might be the better option. It would still require the alignment adjustment, but it would be a 'once and done' type thing, and shouldn't affect ride quality. -Scott |
02-10-2019, 11:53 AM | #4 |
Drives: 2SS/RS LS3 NPP Join Date: Feb 2018
You can have spacers machined up for your rear springs, handling and alignment will be affected.
Taylor 409's, BF Comp 2's, Z26 pads, Hurst billet shifter
02-10-2019, 11:57 AM | #5 | |
-Scott |
02-10-2019, 12:03 PM | #6 |
Drives: LT W/2LT,blue metallic Join Date: Jul 2016
im thinking it would mess up your ride and handling to raise the rear too high.my old pontiac was raised in the rear,lowered in the front and the handling wasnt very good.
02-10-2019, 02:30 PM | #7 |
Definitely! Rubber rake, you'll have to re gear to compensate though.
02-10-2019, 03:36 PM | #8 |
Big Crow
Drives: '13 ZL1 Join Date: Mar 2017
02-11-2019, 06:04 AM | #9 |
Drives: '17 Corvette Grand Sport M7 Join Date: May 2012
Lower the front and leave the rear stock. This is your best option for making it look like it's straight outta 1981.
MY RIDE: 2017 CORVETTE GRAND SPORT--TRIPLE BLACK, 7 SPEED MANUAL, VARARAM TCR-7 INTAKE, BORLA CATLESS X-PIPE, CARBON FIBER STAGE 2 AERO, MGW SHORT-THROW SHIFTER
**SOLD**2011 TRIPLE BLACK SS CONVERTIBLE--6 SPEED MANUAL, MANY MODS, 455 RWHP/435 RWTQ DAD'S RIDE: 2012 ZL1 #1866--BLACK, 6 SPEED MANUAL, EXPOSED CF HOOD, POLISHED WHEELS, SUNROOF, ROTO-FAB INTAKE "Silly Americans, taking from the rich and giving to the poor only works in fairy tales. Success is earned here!". |
02-11-2019, 06:53 AM | #10 |
Drives: '10 Camaro SS,Jeep Commander Hemi Join Date: Mar 2010
taller tires, I think "NOT"
There's a limit how much of a difference you can have in the diameter of the front & rear tires because you'll mess up the computer's breaking response.Not only that,your traction & handling will be out the window with the weight transfered changed.
02-16-2019, 02:08 PM | #11 |
Drives: 2013 Camaro SS Join Date: Oct 2016
So is there a good option out there for off the shelf parts to raise the rear end? I too like the raked look but don't want to lower the front I would rather raise the rear.
02-16-2019, 03:34 PM | #12 |
Drives: 2014 2SS/RS Join Date: Jan 2018
There isnt much option other than lowering the front. With independent suspension in the rear it doesnt lend to being lifted up like the old school cars.
Sent from my SM-N960U using Tapatalk
2014 2SS/RS LS3/M6
02-16-2019, 04:22 PM | #13 |
Drives: 2011ss/rs camaro Join Date: Sep 2011
The air shocks and or shackles on the leaf springs to lift the rear of cars was to gain clearance for wider tires. Otherwise the fenders would scrub and cut into the tire,that hung out past the fenders. It worked,and looked cool doing so.
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
02-16-2019, 05:53 PM | #14 |
Wouldn't taller springs or a spacer achieve the goal of raising the rear end, even with independent rear suspension? I assume the issue is nobody is making said parts.
