Just another car Jones!
tire traction on very slow turn
Not sure how to phrase the question. I have the zl11le. I notice that when I either back up or move forward and sharp turn wheels, I get this traction feel or sound that feels like tires are not gripping or chatter.
Is this to do with TControl or what? just curious as any sound that seems foreign I will research. thanks. fred z |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
I noticed that on the stock GY Supercar tires when I ran them. I think it's the fact they are slick as glass when not up to temperature. I believe it is exactly what you noted- the tires slipping across the pavement. Only did it when the tires weren't warmed up (such as cutting the wheel to back out of the driveway).
Others might chime in, but you'll probably get more responses over in the 6th gen section.
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp // CSP LT's & Ultra Cats // BMR MM // BC Forged KL13
Mods being installed- oil pump, cam, ported heads, dual in-tank, Goliath and XDI, corn, etc., etc. |
sounds right Rob, thanks.
![]() Drives: 14 ZL1 Join Date: Mar 2014
It is typical of a clutch style limited slip diff as they have preload springs that provide some amount of "locking" without any torque input. This is causing the inside tire to try and rotate as fast as the outside tire and thus slipping a bit.
