![]() Drives: Victory Red 2011 2SS Join Date: Dec 2016
Made my own shifter for my auto.
I saw Elvis66 posted a White Madness shifter a week or so ago and decided I would order one. I already had a manual shifter boot in the car but was using the stock shifter.
I put the White Madness shifter in and while it is a great design and well thought out and great finish, I wasn't happy with how it looked with the manual shift boot. I was going to make an adapter for the boot but then decided to just make my own shifter instead. I took some 2.5" solid AL stock I had and started turning it down until I had my desired shape. Then I figured out the actual length and cut it to size. Then I hollowed it out and tested it to make sure it worked like I wanted it to. Next step was to machine a piece of delrin as a bushing to the metal on the shifter so I wouldn't have metal to metal rubbing. I threaded it for a 12x1.25 because I couldn't find a CF ball I liked in the 12x1.75 thread. Lastly I milled a slot in it and turned down a screw to hold it all in. I am not quite finished but far enough along to share what I have. I will be ceracoating the screw head with "micro slick dry film coating" to help with any seizing but I don't think it will be a problem if I didn't...I just would rather do it just in case. I am NOT a professional machinist, and I wouldn't even say I am a hobby machinist...I am more of a "I got a good deal on some big machines from a friend and I like to play and use them some" machinist LOL. I used to use them a good bit to make collectible lightsaber hilt parts and even entire hilts but I haven't used them in quite a while so it was fun to use them again. The shifter ball I ordered will hopefully be in on Thursday or Friday and I will update the post when I have that pic. Until then here are some progress pics. OK all the images are rotated...sorry about that but I do not know how to fix it. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
![]() Drives: 2016 SSupercharged, 2012 Camaro SS Join Date: Sep 2016
Please put me at the top of the list if you decide make some more. Extremely interested.
Thanks
Following as well. Already have the manual shift boot upgrade. Liking what i see here.
2016 Chevy Colorado (Daily Driver)
2013 Camaro 2LT/RS (Traded 2020) |
Would like to be 3rd on the list! Looks Awesome!
![]() Drives: 2014 2SS RS, 6 sp man Join Date: Feb 2016
Nice job
#6 |
Instagram: Sangstah
Very clean and well made, wish I had your skills, came out awesome!
#7 |
![]() ![]() Drives: '14 BRM 1LE 2SS/RS Join Date: Nov 2017
Fancy! Nice work
592 HP/590 TQ
LSA Blower w/ 2.45 Griptec, Reinforced Brick, FIC 1000 injectors, JRE FPCM, LFP Dual Pass HX, ZL1 IC pump, RotoFab CAI, Bo White TB, Coated Stainless Power 1-7/8" LTs, NPP, NGK TR7IX, Mighty Mouse Wild CC, AEM X-Series WB, Aeroforce Interceptor, MGW Shifter, Z28 Grill, Gary's Custom ZL1 Rockers, Hero Tails, Tuned by IMC |
#8 |
A true artist
#9 |
Thanks everyone. I do not have plans to make anymore right now. It doesn't look like much but it was several hours of work on my manual machines and I have several projects going on right now (I work full time and run a side business).
I will speak with a friend of mine that has a CNC machine shop and see if its feasible to take my design and machine it but he is pretty swamped as well so I am not sure its something he would take on. |
#10 |
![]() Drives: 2010 Camaro 2SS/RS M6 Join Date: May 2009
Beautiful work. I wish I had your skills.
GPI SS2; EE E2 catch can; SP 1 7/8" LT Headers w/ hfc; FM AT 3" cat-back; CAI Cold Air Intake; AEM Wideband
Tuned by GPI McCleod RXT; MGW flat stick; Ram Clutch slave cylinder & hydraulic adjuster BMR cradle & diff bushings, trailing arms, toe rods & upper control arm bushings Hotchkis sub-frame brace Stop Tech Z-23 brakes 4.10 gears, Eaton Truetrac, LPW diff cover Best 1/4 mile 12.073 @ 115.68 mph 3,300 ft DA |
#11 | |
Great work man, would really like to have one if you decide to move forward and build a couple more Sent from my iPhone using Tapatalk
#12 |
Ret AF, cancer survivor
Drives: 2013 Camaro 2SS/RS & 2006 Corvette Join Date: Jul 2015
Very nice work, looks great .. well done
#13 |
Drives: 2019 SS 2019 mustang GT Join Date: Apr 2017
Great job!!! Looks great .so after playing with the shifter I found away to adjust the boot.. simple zip tie inside the boot .. really like how yours turned out it's much more like the white madness did for automatic mustang..
#14 |
Nice work!
