Old 02-17-2019, 08:17 PM   #1
FartOolong
Drives: 2015 Chevrolet Camaro 1LS
How many quarts of lube do I need for the rear differential?
Planning on replacing the rear diff. fluid on my 2015 V6. How many quarts am I going to need? I’m planning on using Mobil 1 75W-90 LS since it already has LS additive.
FartOolong is offline   Reply With Quote
Old 02-17-2019, 08:25 PM   #2
polizzio
polizzio's Avatar
Drives: 2012 1LT SIM Camaro
1 quart for the replacement.
But if you plan on squeezing the quart bottle to refill diff after draining, purchase 2 quarts. Getting that last 3 or 4 ozs out of the bottle is tough, because of the tight location and elevation of the bottle itself in relation to the diff. After you finish the job, transfer the almost empty bottle to the fuller, and save for the next replacement.
polizzio is offline   Reply With Quote
Old 02-17-2019, 08:54 PM   #3
bkevind
bkevind's Avatar
Drives: 2013 2SS RS 1LE
Ditto. I get two quarts at a time, I use a hand pump screwed directly into the bottle. it doesn't get the last bit from the bottom, so I need to add a bit from the second bottle, then I pour what's left of the first one into the second bottle when I'm done.
468, Mishimoto rad + oil cooler, TSP LTH
MCS 2WNR
CTSV/ZL1 front calipers/rotors + G-Loc
Forgestar CF-5 19x11
bkevind is offline   Reply With Quote
Old 02-17-2019, 09:00 PM   #4
0-120
Drives: 2014 Camaro SS LS3
Or just get a transfer pump and one quart then reuse the transfer pump for other jobs like trans fluid, etc.
416HP, 422TQ. Rotofab CAI, Dyno Tuned. ALP's and a V1.
0-120 is offline   Reply With Quote
Old 02-17-2019, 09:14 PM   #5
FartOolong
Thanks. I already have about 1.5 qts of the oil left from earlier so I should be good to go.
