Old 02-18-2019, 12:16 PM   #1
Cheap Guy
Cheap Guy's Avatar
Drives: 2011 Camaro SS
Bilsteins out of stock
Since the Bilsteins are apparently still out of stock, are the 1LE struts/shocks the next best and cost efficient shocks-only alternative?
My Little Mid-Life Crisis Cure!
First - 1997 Camaro 3800 Y87, M5, Green - Gone | Second - 1997 LT1 Z28, M6, Silver - Sold | Third - 1999 LS1 Z28, M6, Pewter, Almost Stock! - Sold
Current - 2011 Camaro SS, M6, black, 1LE suspension parts - Current
Cheap Guy is offline   Reply With Quote
Old 02-18-2019, 12:29 PM   #2
SSEssence
Instagram: Sangstah
Drives: 2019 Camaro 1LE
You could also look into Konis
SSEssence is offline   Reply With Quote
Old 02-18-2019, 01:56 PM   #3
Alicia
Drives: 2015 Chevrolet Camaro
This is a dream!Especially that grey one
Alicia is offline   Reply With Quote
Old 02-18-2019, 02:31 PM   #4
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Only Oranges are available at this time - no yellows
Old 02-18-2019, 04:06 PM   #5
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
You cant get Koni Yellow or Bilstein for the Camaro, probably not for a very long time, if ever.
2015 1LE, TSP 225/236 113+3, VMAX Throttle Body, CAI with race scoop, GPI Ported Intake, Land Speed Stage 2 Heads, 1-7/8 headers, NPP exhaust, 25% Fluidampr, LT1-S Monster Clutch, 485 RWHP & 444 TQ
zz430camaro is offline   Reply With Quote
Old 02-18-2019, 05:43 PM   #6
Cheap Guy
Cheap Guy's Avatar
Man, I’ve spent all day reading threads on what I should do. There were a few sellers of the Bilstein B6 on eBay but I’m wondering if they’re legit or simply listing stuff that’s on back order like everyone else.
I’ll probably go with the 1LE setup which I can get for less than $350. The Koni Orange are available too for around $450 but are they worth the extra $100 over the 1LE parts?
Old 02-19-2019, 09:29 AM   #7
derieu
Engineer
derieu's Avatar
Drives: 2014 Camaro 2SS RS 1LE
PED-149086L, PED149086R, PED-144341 x 2
Pedders Sport Ryder Shocks.
2014 Red Hot Camaro 2SS RS 1LE
-Sunroof Delete, Recaro, Nav, NPP
-Pegasus Subframe Bushings, JPSS Radius Insert, Detroit Speed Caster Mod, PMAS Intake, Solo High Flow Cats, Ecsta PS91 Tires, MGW Shifter, Pegasus Offset Poly Diff Bushing
derieu is offline   Reply With Quote
Old 02-19-2019, 10:19 AM   #8
ZEN357
ZEN357's Avatar
Drives: 1991 Z/28 Convertible
Here are some choices for you depending on your budget...
https://www.jegs.com/c/Steering-Susp...29854&sbv=true
ZEN357 is offline   Reply With Quote
Old 02-19-2019, 07:40 PM   #9
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
4th Gen
This link is all 4th Gen Camaro stuff.
Here's 5th Gen not a lot of choices.
https://www.jegs.com/webapp/wcs/stor...ear=4294829656
Orange Krush II
Old 02-19-2019, 10:05 PM   #10
Cheap Guy
Cheap Guy's Avatar
Thanks for the links but I’m really hoping for first hand experience with the various options, specifically 1LE parts versus Koni orange or Pedder since they’re actually available.
Old 02-20-2019, 02:36 AM   #11
terry_b
terry_b's Avatar
Drives: 2014 2SS/RS 1LE
Send a message via MSN to terry_b
I was stuck in this spot recently... I was almost talked into coilovers, but ultimately just went with replacement OEM shocks/struts for cost effectiveness. I'm using the extra budget to install a MGW shifter instead!
terry_b is offline   Reply With Quote
Old 02-20-2019, 07:54 PM   #12
SummitWhite11
SummitWhite11's Avatar
Drives: 2010 2LT/RS
I have the Koni Orange Srt.T Struts on my Camaro and love it. No issues.
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Sided Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links, Aluminum Blend Door, Evil Energy Catch Can.
SummitWhite11 is offline   Reply With Quote
Old 02-21-2019, 02:47 PM   #13
Avenging Orange
Avenging Orange's Avatar
The best first hand experience is doing your research, making an educated choice and installing it. Everyone else's experience is simply an opinion.
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
Old 02-21-2019, 08:54 PM   #14
Blueovalman
Blueovalman's Avatar
Drives: 2012 V6 Camaro 2010 Camaro SS
Arrow
The Bilstein struts and shocks were the best quality struts and shocks we ever installed on our 2010 Camaro SS and were well worth it and then some. If you guys search there are reputable vendors that have the Bilstein struts and shocks in stock and sell them. Also I don’t know why you people don’t purchase your Bilstein struts and shocks for your Camaro direct from Bilstein?? Bilstein said there struts and shocks are in stock and are really to ship.
Mr. Clean
Blueovalman is offline   Reply With Quote
