Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Members Classifieds - Parts for sale or wanted > ZL1 Parts
Old 02-18-2019, 03:15 PM   #1
A2Didit
Drives: 2010 Camaro SS
WTB Stock ZL1 Torque Converter
Hey guys, lsa swapping my ss, and in the need for a stock zl1 torque converter. Yes i know i could go aftermarket. Working on a budget. Thanks
A2Didit is offline   Reply With Quote
Old 02-21-2019, 04:02 PM   #2
A2Didit
Any torque converters out there??
Old 02-22-2019, 07:00 PM   #3
A2Didit
Anything?
Old 02-23-2019, 01:29 AM   #4
Dylan1214
Dylan1214's Avatar
Drives: 2014 Camaro SS L99
I have a stock SS convertor with 9,800 miles. Not sure if they are the same or not.
MODS: GPI MAX Package ported and milled heads+(229/250,111 LSA),Johnson 2110 Lifters,BTR .660 Springs,CHE Trunnions,C5R chain,DSX Flex Fuel kit,LSA Injectors,ZL1 Fuel Pump,MAMO Ported MSD Intake manifold,BOWhite ported Throttle body,25% UDP,CAI Intake,Intake Scoop,Kooks 1 7/8 headers,Borla attak catback,Elite catch can,BMR Motor mounts,CircleD 5C 4000-4200 Torque converter,ADM trans cooler,Jannetty Trans dipstick,DSS Aluminum Driveshaft,3.91 Gears,Eaton TrueTrac,JRE Billet caps,BMR Trailing arms,BMR Toe rods,BMR rear sway bar,Pegasus Solid sub frame bushings,DSS 1,000HP Axles
Dylan1214 is offline   Reply With Quote
Old 02-23-2019, 02:07 AM   #5
John_C
LSx FTW!!!
Drives: 2010 Camaro 2SS RS
They're not.
I got one out of a CTSV / 6L90 and it's a 6 bolt whereas the SS is a 3 bolt.
So his flex plate will also need to have 6 bolt for that converter.
Circle D has the core charge at $380 on the stock LSA converters.
http://www.circledspecialties.com/6l90e-hp-series-300mm
John_C is offline   Reply With Quote
Old 02-23-2019, 12:12 PM   #6
Vandal0-0
Vandal0-0's Avatar
Drives: 2010 CAMARO 2SS/RS
There cheap at the dealership actually. I’m in Canada and the most expensive One was $650 at the dealership. There is 3 different ones to choose from they told me
Vandal0-0 is offline   Reply With Quote
Old 02-23-2019, 04:53 PM   #7
John_C
LSx FTW!!!
OP this is what it looks like,
They have 6 bolts instead E like a stock SS with 6L80.
You’ll need a flex plate with 6 bolt to go with it.
torque converter, zl1
