Old 02-19-2019, 10:19 AM   #1
Arogg
A legend in his own mind
Arogg's Avatar
Drives: 2010 2SS/RS M6
Yes, another tire size question
Sorry if this has been asked before.. I cant use the search feature and other certiain aspects of this site while on my company Wifi. Im ordering tires. I just want to double check my height differences before I order to make sure I don't have stabilitrak issues.
Im ordering 295/40/20 for the rear which is 29.3" overall I believe.
I want to order 275/40/20 for the front which is 28.7 overall I believe.
Is .6" difference between the front and back ok?
-Adam
2010 2SS/RS "The Mistress"
Color matched OEM GFX / VIS Carbon Fiber Hood (absolute trash quality and customer service ) / Heritage Grille / 5% Windows / 30% Windshield tint with 5% visor strip / Tinted Exterior Lights / Streetfighter LA Spoiler / Morimoto XB LED fogs / LED sidemarkers / Airaid CAI / Hurst Short Throw / TSP LT's / No cats / No resonator / Corsa Xtreme Catback / Trifecta Tune / Factory amp replaced / 2 JL Audio 12's / MRR 228 Wheels / BMR Springs / Koni Yellows / R1 Concepts Rotors & Pads
2006 Dodge Magnum RT "The daily"
Arogg is offline   Reply With Quote
Old 02-19-2019, 10:44 AM   #2
charles71
charles71's Avatar
Drives: 2011 Camaro SS
I think it will cause issues as the 275/40/20 tire will make 704 revolutions per mile and the 295/40 will make 689 revolutions per mile. Why not run 315/35/20 in the rear as they have the same diameter as the 275/40/20.
Livernois Stage II Heads & Cam, LS7 Lifters, Ported Intake & Throttle Body, Rotofab CAI, BBK High Flow Fuel Rail @ Guage, Eaton Tru Trac Posi with 3.91 gears, 1000 HP Axels, Kooks Long tubes & full Corsa Exhaust, GM Hurst Short Throw Shifter, Mcleod RXT Twin Disc, Vitesse Throttle Controller, 1.5" Lowering Springs, Strut Tower Brace, SLP 25% Underdrive Pulley, Apex reservoir relocation kit and air scoop.
charles71 is offline   Reply With Quote
Old 02-19-2019, 11:04 AM   #3
Arogg
Arogg's Avatar
So heres the thing. I have the 295/40s already pretty much. a buddy ordered them, then totaled his car so I bought them off him pretty cheap. So what size fronts can I run? The fronts are 20 x 9
Old 02-19-2019, 11:08 AM   #4
Arogg
Arogg's Avatar
So. I never thought of the RPM on the tire. But I looked up stock ZL1 sizes, and they are off by 14rpm, my sizes are off by 15rpm... Also, the difference in stock ZL1 is .5 inches, im looking at a .6 difference
Old 02-19-2019, 11:11 AM   #5
charles71
charles71's Avatar
Tire size calculator.com take a look at this site. It will give you all the info you need. But I would wait a few and see if someone that has that set up chimes in. I run 275/40/20 in front and 315/35/20 in the rear. No issues at all
Old 02-19-2019, 11:15 AM   #6
Arogg
Arogg's Avatar
Yea, im on a similar site. Tiresize.com/height-calculator/
Im just curious what the tolerances are for the car/stabilitrak. Hopefully someone chimes in before I roll the dice and order
Old 02-19-2019, 11:25 AM   #7
silverstorm
silverstorm's Avatar
Drives: 2014 Camaro 2LS
I believe you would have to run 265/45. I would check a tire size calculator to see what runs similar to your stock tires or to your 295s. Just know the speedometer will say youre going about 1-2 mph less than what you're actually going.
Link to tire size calculator: https://www.discounttire.com/learn/tire-size-calculator
silverstorm is offline   Reply With Quote
Old 02-19-2019, 11:41 AM   #8
CH.CRAFT
CH.CRAFT's Avatar
Drives: 2018 HOT WHEELS SS 6 SPEED COUPE
I INSTALLED NEW RIMS AND TIRES ON MY ZL1. 28.0”F-28.8”R=2.8% ACTUAL TIRE MEASURMENTS WITH NO LIGHTS OR PROBLEMS.
YOU ARE 28.66”F-29.29”R=2.2% PER TACOMAWORLD.COM TIRE SIZE CALCULATOR. JUDGING BY MY CAMARO I WOULD BELIEVE YOU ARE OK.
I ORDERED M/T ET STREETS 305/35/20 AND DID NOT REALIZE THAT THEY WERE TALLER THAN A STANDARD TIRE, I WAS AFRAID I WAS GOING TO HAVE PROBLEMS BUT DID NOT.
2017 QUICK 16 TRACK CHAMPION
STATE CAPITOL RACEWAY
RACE TRACK CHAPLAIN FOR 30+ YRS
CH.CRAFT is offline   Reply With Quote
Old 02-19-2019, 11:41 AM   #9
Arogg
Arogg's Avatar
The issue with going 265/45 is that will make my front tire .2 taller than the rear.. definitely don't want that.
Old 02-19-2019, 11:44 AM   #10
Arogg
Arogg's Avatar
I think I follow what you are saying ( even in all caps lol ). I believe I am fine as well as im so close to the difference zl1s have from the factory but im still trying to find online what the tolerances are but my company wifi limits a lot of what I can look up ( I guess they want me to work or something ).
Old 02-19-2019, 11:51 AM   #11
CH.CRAFT
CH.CRAFT's Avatar
I READ ALL CAPS BETTER. I SAW ONE POST THAT CLAIMED THAT UP AROUND 5 OR 6 PERCENT IS WHERE THE PROBLEMS START.
DO YOU WANT “AS WIDE AS POSSIBLE” TIRE ON FRONT ?, IF NOT YOU COULD GO WITH A DIFFERENT SIZE.
Old 02-19-2019, 12:18 PM   #12
SSEssence
Instagram: Sangstah
Drives: 2019 Camaro 1LE
You should be fine, I'm running the same sizes minus height: 275/35 up front, 295/35 rear with no issues.
SSEssence is offline   Reply With Quote
Old 02-19-2019, 12:22 PM   #13
0-120
Drives: 2014 Camaro SS LS3
Try a google search: tire size site:camaro5.com
416HP, 422TQ. Rotofab CAI, Dyno Tuned. ALP's and a V1.
0-120 is offline   Reply With Quote
Old 02-19-2019, 12:29 PM   #14
CH.CRAFT
CH.CRAFT's Avatar
THERE YA GO
