Old 02-27-2019, 08:47 PM   #1
Jordansanch
Drives: 2015 camaro ss
2015 camaro ss lsa help no crank
I've been installing a Adm lsa kit. I also installed the dsx flex fuel at the same time. Went to crank the car over for the first time after install no crank. I have 2 codes one is 0100 lost communication with ecm A. Second is p2535 ignition switch circuit high. I had the battery disconnected during install. I have rechecked the grounds, the ecm pins, tried clearing the codes but no dice. Also service stabikitrak is on, and a notification saying no ac engine tempt to hot. Any help fixing this would be great guys!
2015 Camaro ss,cai,long tubes, dsx flex fuel, lunati cam.
Jordansanch is offline   Reply With Quote
Old 01-02-2023, 07:12 PM   #2
210foo
210foo's Avatar
Drives: 2014 Camaro 1LE
Did you ever figure out the problem? I was having the similar issue for a while and now my car will finally start but I still have the codes and the idle is higher than usual
210foo is offline   Reply With Quote
forced induction, lsa
