Old 03-01-2019, 10:35 PM   #1
anorman91
anorman91's Avatar
Drives: 2010 nightfury FBO S/C 2SS
Zl1 pump max?
I have a zl1 pump unlocked and running on my boosted/cam 2010ss set up .
My tuner claims there’s no need for a BAP just larger injectors as my 65# were maxed at 646whp. I have the injectors . My question is where do these pumps max out at . Goal is 750 .
Thanks guys
2010 2SS Camaro
376 LS3 night fury cam package / Torqstorm Supercharged
Instagram: Norman_performance
anorman91 is offline   Reply With Quote
Old 03-02-2019, 05:45 AM   #2
hou30guy
Drives: 2011 convertible 2ss/rs
Add a aux pump in line with hobbs switch, or upgrade to duel pump, any thing pass what u have now is risky
Sent from my SM-N950U using Tapatalk
hou30guy is offline   Reply With Quote
Old 03-13-2019, 08:56 AM   #3
eLeSthree
Drives: 2011 Camaro SS 6sp
Thanks guys
It depends on your injector size.
My friend is running a Procharger P1sc stage 2, cam, exhaust, e85, ZL1 pump, KB BAP, and ID1300x2 injectors. He makes 745whp on his tuners dyno.
I log his car occasionally to check its health, his commanded FP is 58psi, but it drops as low as 43psi. Since he has such large injectors, his tuner can tune around it.
But it is a clear sign that his pump cant keep up. If you are on 93, that will require 30% less work from the pump, depending on the size of your injectors, you might be ok.
I think you should run a BAP.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
Old 03-13-2019, 12:35 PM   #4
Kelly@PCMofNC
Drives: 2010 RS/SS
Thanks guys
If you are logging fuel pressure I can guarantee it's dropping right now already, and the IDC is maxxed as well.
Having larger injectors lets you flow more, but does nothing for pressure. Without pressure you are just having the injectors stay open longer, driving up the IDC. Can it manage the AFR like this sometimes, yes, but it is not the ideal way to do things.
I would either add a better pump or a BAP, both for where you are at now and where you want to be at 750.
Kelly@PCMofNC is offline   Reply With Quote
Old 03-13-2019, 08:32 PM   #5
anorman91
anorman91's Avatar
Just got back from the tuner yesterday with 160s from snake eater , the zl1 pumps’ voltage is increased and he says no need for a BAP . Yes the injectors are large for my application but I was thinking ahead . It’s tuned around the gap from 160lbs to 58psi or pressure but the car doesn’t run as smooth as I’d like . In line fuel pump is a bigger hassle than I’d like so I’m contemplating my next move. 750 just isn’t in my cards currently
2010 2SS Camaro
Old 03-13-2019, 08:33 PM   #6
anorman91
anorman91's Avatar
Looking at gauges currently to monitor fuel pressure as well as boost . Thinking about running meth as well
2010 2SS Camaro
Old 03-14-2019, 06:11 PM   #7
Batmanntexas
Batmanntexas's Avatar
Drives: 2012 Camaro SS (2SS)
Depending on what you consider a hassle, an in-line aux pump could be just the ticket.
- If you cut the floor under the rear seat to get to your fuel pump, then the aux pump would be a hassle.
- Without a hole under the rear seat, dropping the exhaust, driveshaft, and partially lowering the rear cradle, then dropping the gas tank.....now that's a hassle! I've done it twice now.
160's should give you PLENTY of room to grow!! @800rwhp, my 95# (@43.5psi) are about 70% IDC on E-85.
-Scott
745RWHP/634RWTQ on 93 @ 10psi
806/676 on E85 @ 10psi
Currently @15-16psi....
COTW 9/8/14
Batmanntexas is offline   Reply With Quote
Old 03-25-2019, 01:13 PM   #8
johnnyb305mia
Drives: 2015 Camaro SS 1LE
With 1000cc injectors on Nitrous E85 fuel pump tapped out at 600. Just what mine did. no BAP i think BAP are a waste of time.
johnnyb305mia is offline   Reply With Quote
Old 03-28-2019, 03:28 PM   #9
RealQuick
Drives: 2010 Camaro 2SS M6 - Intake/Exhaust
ZL1 pump + AMD FPCM + 1000CC on 93 octane and 100% meth
844rwhp/913rwtq on dyno...
RealQuick is offline   Reply With Quote
Old 03-28-2019, 03:44 PM   #10
IKILLEDSUPERMAN_ZL1
Is the AMD FPCM needed with the ZL1 pump or can the tuner adjust the stock FPCM to do the same thing?
2011 Camaro 2SS, 6.0 iron block forged bottom end, Dart heads, BTR intake, Huron twin turbo kit, Summit stage 3 twin turbo cam, Circle D stage 4 6L90, 3800 FTI converter. BMR suspension, Viking coil overs, Fore triple pump fuel system.
IKILLEDSUPERMAN_ZL1 is offline   Reply With Quote
Old 03-28-2019, 04:18 PM   #11
John_C
LSx FTW!!!
Drives: 2010 Camaro 2SS RS
I think you’d be fine with a DSX auxiliary pump.
They have 2 versions.
One kicks on at 4psi boost and the other kicks on at 9psi boost.
John_C is offline   Reply With Quote
Old 03-28-2019, 04:19 PM   #12
John_C
LSx FTW!!!
Link to pump
https://dsxtuning.com/collections/au...nt=58596002379
Sent from my iPad using Tapatalk
Old 03-28-2019, 10:18 PM   #13
RealQuick
If I recall, I had to adjust the tube for it.
Old 03-29-2019, 01:09 PM   #14
rgrmoreira13
rgrmoreira13's Avatar
Drives: 2015 2SS 1LE
With that setup you are staying 600 at the wheels or 600 at the crank ??
I am saving for a fore system dual or even a triple (depending how I will stage it.) I wanted to make sure that fuel wouldn't be an issue.
Specs
TSP Stage 2 Boosted Cam 227/235 at 114 LSA
Fore Innovation Triple pump staged (Walbro 342 primary and 2x Walbro 450 secondaries)
Procharger D1x with a 3.85 pulley
ID1050x Injectors
Flex Fuel Sensor
Monster LT1 Twin Disk Clutch
Holley Sniper Efi Intake Manifold
NW 103mm Boosted TB
747rwhp at 12psi on E85
rgrmoreira13 is offline   Reply With Quote
