Old 12-03-2009, 01:12 PM   #1
GOINGSOLO2
GOINGSOLO2's Avatar
Drives: All Models
Solo Performance LS3 Mach-X Exhaust Kit
Solo Performance is proud to offer the Mach-X exhaust kit for the LS3 Camaro.
The Mach-X Cat-Back kit uses 2.5" mandrel-bent T409 stainless steel pipes with our T304 stainless steel Mach-X muffler (T304 inside and outside). The muffler was designed and engineered differently than most other X-style mufflers. The inner compartment is split into four different chambers, each with ceramic fiber and stainless steel wool packing. It is a true "X" design and creates a low pressure system, while the four chambered design ensures the packing won't break apart and change the sound and efficiency over the years. It is a dual 2.5" in and 2.5" out design. GM needed to get around some clearance issues and had some flat spots in the exhaust. Our design has eliminated all flat spots and is a mirror-image design, unlike the GM factory system. The differential gave GM a hard time accomplishing this, but we painstakingly have. The tips are 4.5" round, double-walled and beveled, cut on an angle to compliment the rear fascia.
Install: Direct Bolt-On (instructions are attached at the bottom of this post)
Mach-X Video
Pictures
Also, please see the video compilation link in my signature for even more videos of our exhaust kits.
File Type: doc Instructions for MACH X Exhaust KIT BUYERS.doc (82.0 KB, 155 views)
GOINGSOLO2 is offline   Reply With Quote
Old 12-03-2009, 03:00 PM   #2
GOINGSOLO2
GOINGSOLO2's Avatar
Drives: All Models
To accommodate the GFX kit, we offer rectangular tips with these kits. The tips will come unattached with an extra section of straight pipe for each side at no charge. Your installer can weld the tips on as far in or out of the GFX outlets as you like. The tips look like this:
SOLO PERFORMANCE makes two EXCELLENT Exhausts for the 6.2L V8 Xmicro_SS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 106 04-19-2010 10:11 PM
PERRIN Performance Water/Methanol Injection Kit PERRIN_JOHN Forced Induction 4 03-17-2010 10:57 PM
Official 2011 Mustang V6 HP/TQ Revealed. syr74 General Automotive + Other Cars Discussion 408 12-06-2009 10:50 PM
Solo Performance V6 Mach-XL (Manual) and Mach-XLT (Auto) Exhaust Kits GOINGSOLO2 Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 4 12-03-2009 02:59 PM
5th Gen Camaro LS3 info from Chevy Hi-Po...READ TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 295 03-07-2008 11:06 AM
