Old 03-09-2019, 01:49 PM   #1
RalphGuevara
ZeusRS
RalphGuevara's Avatar
Drives: 2013 Camaro 2LT|RS
Anyone know how to clear a check engine light because of No Cats?
I had recently installed some American Racing Headers on my 13' RS but im getting a check engine light from the O2 Sensors since i removed the cats.
I was looking around on the forum if anyone has used Non Fouler's for a fix but some people are saying that it doesn't work.
If anyone has information or tips to help me get rid of this light it would be much appreciated!
RalphGuevara is offline   Reply With Quote
Old 03-09-2019, 02:12 PM   #2
ZZZTOPZZZ
ZZZTOPZZZ's Avatar
Drives: 2013 L99 2SS Vert
What you are experiencing is pressure change. I went through the same thing when I installed my Stainless Works headers, tubes, and cats. You most likely will need the services of a tuner and you can expect a nominal charge.
ProCharger Stage II - Stainless Works Headers - Long Pipes & Cats - ZL1 Fuel Pump - Cam On The Way Next Spring
ZZZTOPZZZ is offline   Reply With Quote
Old 03-09-2019, 02:20 PM   #3
RalphGuevara
ZeusRS
Around how much did you pay for a tune?
Old 03-09-2019, 02:34 PM   #4
ZZZTOPZZZ
ZZZTOPZZZ's Avatar
At that time it wasn't a full tune. Just clearing the fault won't fix the problem. It ran about $125 but the tuner did everything in the way of a tune short of putting it on the dyno. Check around for a good speed/racing shop. I'd stay clear of auto dealerships.
check engine, exaust, non fouler
