Old 03-12-2019, 06:00 PM   #1
Matt8892(2)
Drives: Black camaro 2ss 45th
Ikon side skirts and marker light tint
Had the side skirts sitting around since chirstmas. Got some nice weather and had to get it done. I got stainless steel screws instead of using the screws that they came with because I didn’t want to deal with rust.
On a side note, the side skirts are so low to the ground it’s scary, and I have no idea how I’ll ever get all 4 tires on the air at the same time again with a floor jack and stands
Matt8892(2) is offline   Reply With Quote
Old 03-12-2019, 06:03 PM   #2
SSEssence
Instagram: Sangstah
Drives: 2019 Camaro 1LE
I use a Harbor Freight low profile jack and it just barely squeaks by under the side skirt at the jack points. The other option is nail a few 2x4s together to drive up until you have enough clearance up front to slide the jack under.
SSEssence is offline   Reply With Quote
Old 03-12-2019, 06:06 PM   #3
Spec
Drives: 2010 Camaro 1SS LS3
Get yourself a pair of 2x4's... or like me, a stack of plywood...
Spec is offline   Reply With Quote
Old 03-12-2019, 06:53 PM   #4
Camaro2ss2010
Camaro2ss2010's Avatar
Drives: 2010 Camaro 2SSRS M6
Yellow jacket makes a lower than normal low profile jack. I can measure mine if you want to know how high it is just sitting there. They are not real expensive either.
Camaro2ss2010 is offline   Reply With Quote
Old 03-12-2019, 07:13 PM   #5
Matt8892(2)
I’m due for a new jack. Mine is seriously shot. I didn’t even think about a low profile jack. I’ll have to see what’s around. I can only fit 4 fingers under the side skirts.
Old 03-12-2019, 07:14 PM   #6
Matt8892(2)
I would really appreciate if you could. I’ve mever heard of them before
Old 03-12-2019, 09:00 PM   #7
Camaro2ss2010
A few pics of the jack
. Here are a few pics of the jack. Maybe it will work for you.
Old 03-13-2019, 12:00 AM   #8
Glassman66
Glassman66's Avatar
Drives: 2014 Camaro 2SS/RS 1le
I gotta get those side skirts, bad ass
https://www.camaro5.com/forums/image.php?type=sigpic&userid=124840&dateline=15563  941302014 Camaro 1LE SS/RS THE MISTRESS
Glassman66 is offline   Reply With Quote
Old 03-13-2019, 11:04 AM   #9
Matt8892(2)
Thanks for measuring man. I’m 3.5 inches of ground clearance. So I’ll have to use a small board with a jack like that which may work.
Old 03-13-2019, 12:40 PM   #10
Panda1LE
Panda1LE's Avatar
Drives: 2013 2SS/RS 1LE (6spd)
Yea those side skirts look great and def on my list!
Panda1LE is offline   Reply With Quote
Old 03-13-2019, 12:46 PM   #11
J Rod
J Rod's Avatar
Drives: '14 BRM 1LE 2SS/RS
Well crap, gonna have to cross those off my future mod list. They look great but there's no way I'd clear the curb in front of my driveway with those.
592 HP/590 TQ
LSA Blower w/ 2.45 Griptec, Reinforced Brick, FIC 1000 injectors, JRE FPCM, LFP Dual Pass HX, ZL1 IC pump, RotoFab CAI, Bo White TB, Coated Stainless Power 1-7/8" LTs, NPP, NGK TR7IX, Mighty Mouse Wild CC, AEM X-Series WB, Aeroforce Interceptor, MGW Shifter, Z28 Grill, Gary's Custom ZL1 Rockers, Hero Tails, Tuned by IMC
J Rod is offline   Reply With Quote
Old 03-13-2019, 12:59 PM   #12
BLU DUCE
BLU DUCE's Avatar
You can get a great low profile jack at Harbor Freight.
Old 03-13-2019, 01:35 PM   #13
J Rod
J Rod's Avatar
I got one of these for $79, great deal and well made.
https://www.ruralking.com/3-ton-low-...-hd-steel-jack
Old 03-14-2019, 12:44 PM   #14
blewbyyou
blewbyyou's Avatar
Drives: Dusk SE
Not a fan of those they look like running boards. prefer the OEM ZL1 style.
Daily Drives Dusk SE 2SS/RS
blewbyyou is offline   Reply With Quote
