Old 03-13-2019, 02:20 PM   #1
krisprz2010camaross
krisprz2010camaross's Avatar
Drives: 2010 Camaro 2ss/Rs Transformers
Bluetooth Flex Fuel sensor analyzer. I recommend!
Just installed a “Fuel-It !”Bluetooth flex fuel analyzer on my 2010 camaro ss. Now I can read what % E85 I have in the tank from my phone. No need for an E85 gauge or using a E85 tester tube.
Have been running flex fuel for awhile and decided to order one of these along with a flex fuel sensor for my 2018 Golf R.
Easy install plug and play if you already have a flex fuel sensor installed. The “Fuel-It!” App is $4.99 in the App Store which kinda sucks, but works great!
Here are some pics.
YouTube:Krisprz garage
Insta:kris__perez & krisprz_garage
LS3 conversion
Vararam intake(tune model)
Kooks LT headers & cats delete
Corsa ZL1 3" exhaust
RedBarn Racing Tune
CMS Stage 3 Cam
AFR CNC ported heads
MSD Spark plug wires
LNC-2000 Launch controller
NGK TR6 Spark Plugs
1le strut tower brace-TPIS spacers
Nick Williams 102mm throttle body
Fast lsxr 102 intake manifold
Slp 25% UDP
Katech Tensioner Pulley
Circle D 3600-3700 multi disk Stall
GM 3.91 gears
DDS carbon fiber driveshaft
ZL1 fuel pump & injectors
Flex fuel sensor(91/E85)
https://wheelwell.com/kris-perez
krisprz2010camaross is offline   Reply With Quote
Old 03-13-2019, 02:38 PM   #2
hammdo
'It's an experiment'
hammdo's Avatar
Very Cool!
If you enabled the sensor in the ECM, it’s also available on the OBDII port. Torque app can show it with a Bluetooth OBDII sender...
-Don
747 RWHP 794 RWTQ
Old 03-13-2019, 02:44 PM   #3
krisprz2010camaross
Originally Posted by hammdo View Post
Very Cool!
-Don
Nice! I didn’t know that.
I don’t have an Android phone to get the Torque app though. I also have a P3 Gauge connected to my OBD port. Also, he Fuel-It is available for Apple and Android
LS3 conversion
RedBarn Racing Tune
CMS Stage 3 Cam
NGK TR6 Spark Plugs
Slp 25% UDP
GM 3.91 gears
Old 03-13-2019, 02:47 PM   #4
hammdo
hammdo's Avatar
Yea, there other apps like torque that do that also. I have the AeroForce duals and nGauge on OBDII port (when it will let me run both ;o)
This is a nice option though!
-Don
747 RWHP 794 RWTQ
Old 03-13-2019, 05:15 PM   #5
silversleeper
Big Crow
silversleeper's Avatar
Drives: '13 ZL1
I got the FUEL IT 4.99 app hoping it would work with IOS and OBD dongle. Nope, re-reading everything it clearly has it's own bluetooth built in and the app won't read off the OBDII.
https://www.fuel-it.com/bluetooth-flex-fuel-analyzer/
I have the TORQUE PRO and an old android phone and OBDII readers, might go back to that for handheld simplicty.
silversleeper is offline   Reply With Quote
Old 03-13-2019, 05:38 PM   #6
krisprz2010camaross
You need the Bluetooth analyzer from Fuel It that plugs into your flex fuel sensor. It doesn’t read from OBD port
LS3 conversion
RedBarn Racing Tune
CMS Stage 3 Cam
NGK TR6 Spark Plugs
Slp 25% UDP
GM 3.91 gears
