![]() Drives: Chevrolet Camaro 1LT Join Date: Mar 2019
2011 Camaro V6 Exhaust and Intake Suggestions!!!!!!!!!!!!
I just bought a camaro v6 and I'm trying to give it more power and adding an exhaust that sound mean and aggressive with cracks and pops. What do you guys think i should do in terms of exhaust and which cold air intake do you guys recommend I put on my car?
#2 | |
![]() ![]() ![]() ![]() ![]() Drives: Never just fly under the radar Join Date: Jul 2015
I love my SLP loudmouth, and when you lose the suitcases you also drop about 35lbs.. Some get the X-pipe to prevent drone but I like the way mine sounds. When I down shift been told it sounds like a BOV. Not mine below but sounds close, should here one down shift though might be my favorite part.
It went well with my Volant CAI, ported throttle body, ported intake manifold, and JacFab intake spacer. Don't know if all these are even available anymore. The spacer actually dropped my hp just a couple but increased the much needed torque. Can get some smoke rolling burnouts(legal ones of course) with 315's outback and the stock 2:92 gears. If you want to feel a seat of the pants response from your throttle might look at a throttle controller. Here's a good sticky for mods little outdated though. https://www.camaro5.com/forums/showthread.php?t=222713
Old Skool Last edited by Tajefe Couple; 03-14-2019 at 12:30 AM. |
One of the best sounding systems in mind mind was always the MRT V2 for this car. Its pretty aggressive without being over the top and has a nice deep smooth sound.
As far as the intake goes the CAI and Roto-Fab have always been our best sellers. Both make solid power gains and fit nice and easy. Save some cash on our site with code CAMARO5 or hit us up for a package deal. |
is there a lot of droning?
![]() Drives: 1991 Z/28 Convertible Join Date: Feb 2018
#6 |
![]() Drives: 2012 Camaro LS V6 Join Date: Aug 2016
There is droning on basically every exhaust set-up for the v6. The only exception is the Solo Performance cat-back system because it includes Helmholtz resonators (J-pipes). Unfortunately I think they're mufflers dampen the sound too much for my liking. They don't sound much different than stock imo.
Personally, I have the MRTv2 axle-back welded on. I like the sound a lot, but the drone is a headache from 1800-2200 rpm so I've purchased Solo's adjustable J-Pipes separate. I haven't installed them yet so I can't yet attest to the sound quality, but the Helmholtz principle is a reliable method to cancel noise in a specific frequency so I'm confident it will work without muffling the exhaust note. |
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
Vararam.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ |
#8 | |
![]() Drives: Silver Join Date: Oct 2018
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 RS Inferno Orange Metallic Join Date: Mar 2010
obx or bbk headers and Vararam Intake
#10 |
| Tags |
| exhaust, intakes, opinions, suggestions |
