Old 03-14-2019, 07:12 AM   #1
Matfly
Drives: Camaro V6 1LT 2010
Question v6 Camaro brake
I buy V8 camaro caliper to evolve my V6 brake and I will buy discs. my question is do these discs match?
rear disc : https://www.rockauto.com/fr/moreinfo...44223&jsn=4393
and front disc : https://www.rockauto.com/fr/moreinfo...44223&jsn=4395
it's ok?
ps : my Camaro is V6 of 2010
thanks !
Matfly is offline   Reply With Quote
Old 03-14-2019, 03:39 PM   #2
Matfly
Nobody ?
Old 03-15-2019, 11:10 AM   #3
Matfly
or so do these disc mounts on a 2010 V8 camaro ss ?
Old 03-15-2019, 02:49 PM   #4
KillboyPowerhead
Drives: 2015 Z/22
Those rotors appear to have the correct diameter, thickness and bolt pattern as the factory rotors, so they'll probably fit
Also, to fit the rear V8 rotors on the V6 you'll need to replace or modify the rear dust guard as it will be too small and interfere with the bigger rotor.
Another thing to consider - from what I've read - is upgrading your brake master cylinder to the SS one, although you can get away without it, but apparently it makes a noticeable difference.
KillboyPowerhead is offline   Reply With Quote
Old 03-15-2019, 02:58 PM   #5
Matfly
thank you for your answer, yes I saw that it was necessary to modify the back. and I saw also for the master cylinder. but I would see later!
Old 03-15-2019, 04:01 PM   #6
B.mik
Drives: 2010 LLT RS
Hi,I would recommend these: https://www.amazon.com/K2816-Evoluti.../dp/B005FKBFYU
Huge difference and great stopping power.
B.mik is offline   Reply With Quote
Old 03-16-2019, 11:09 AM   #7
Matfly
thanks you but it's too expensive I have $ 350 delivery
brake caliper, camaro, disc
