Old 03-15-2019, 08:57 PM   #1
BluedEvil21
BluedEvil21's Avatar
Drives: 2013 Camaro v6 hot wheels edition
Getting cammed!
I pulled the trigger and bought mace cams...my question is can I take it to a shop get them installed and limp it home without a tune? At least until I can get will at will overkill to tune it remotely. I just don't wanna do any damage to my engine....thanks for any input
Drop a gear and disappear
BluedEvil21 is offline   Reply With Quote
Old 03-15-2019, 08:59 PM   #2
MagnumForceGB
MagnumForceGB's Avatar
Drives: Fastest 2010 Camaro V6
You can drive it home without a tune, it may just start rough and be sluggish leaving idle.
Camaro V6 = 11.268 @ 120.11
MagnumForceGB is offline   Reply With Quote
Old 03-16-2019, 07:28 PM   #3
BluedEvil21
Thanks magnumforce, I figured just wanted a second opinion
Old 03-17-2019, 09:51 AM   #4
TommyJr
Drives: Mazda RX8 LFX
I'm super curious what will be your impressions. Do you have any other mods?
I advise to dyno the cat before and after on the same dyno.
I'll be doing the some with few extra mods around May.
Sent from my SM-G965F using Tapatalk
TommyJr is offline   Reply With Quote
Old 03-17-2019, 07:29 PM   #5
BluedEvil21
Ya I have a cold air intake, 2015 Colorado manifold, 80mm throttle body, will overkill tune, high flow exhaust, and high stall torque converter... also a jacfab spacer... nitrous have yet to install as well as meth injection...i haven't dynoed I go by my 1/8th mile times
Old 03-19-2019, 12:26 PM   #6
ramil13
ramil13's Avatar
Drives: 2015 Chevrolet Camaro 2LT RS
They aren't much bigger cams than stock it will run fine. Whereas the LS3 etc performance cams makes them sound like a tractor and they run rough without a tune. So dont expect huge gains.
K&N intake, Custom Tune, Billet Catch Can, K.C's Ported 72mm TB & IM, Jacfab IM Spacer, Primary/Secondary Cat & Muffler Delete, Magnaflow Xpipe, 2.5" Straightpiped, GM Strut Tower Brace, Mace Engineering Cams, Solo Performance J pipes, Magnaflow Resonators x 2
340rwhp Dyno
ramil13 is offline   Reply With Quote
