Old 03-18-2019, 07:36 PM   #1
DenverCamaroGuy
Drives: 2011 Camaro 1LT
Angry 2011 3.6L engine noise.
Hey everyone;
New user here and first post. I have a 2011 3.6l I just bought and it has the worst sound. I can't seem to track down where it is coming from. Sounds like a lifter tick but might be a bad rod bearing. Im sure it is isolated to cylinder 3. If you start it up and unplug #3 coil the sound usually goes away almost completely. Any thoughts, advice or suggestions before I teardown the engine completely.
DenverCamaroGuy is offline   Reply With Quote
Old 03-18-2019, 07:55 PM   #2
SimpleGreen
Drives: 2015 2SS/RS
Doesn't explain why it goes away when unplugging the coil but the V6 in these cars has a high pressure fuel pump that I believe is mounted in the rear of the driver side cylinder head and it makes one hell of a tick because its generating over/around a thousand pounds of fuel pressure. It is driven off the camshaft. I noticed it pretty readily on my 2012 V6 I had.
2015 Camaro 2SS/RS SIM
2016 Jeep Wrangler 2DR Willys Wheeler
1993 C1500 Single Cab Stepside 5.3L LS Swap
SimpleGreen is offline   Reply With Quote
Old 03-18-2019, 08:39 PM   #3
StreetRage320
Those who need me got me
StreetRage320's Avatar
Drives: 2022 ZL1 A10
check it in the dark and look for any sign of an arc..
StreetRage320 is offline   Reply With Quote
Old 03-18-2019, 11:25 PM   #4
DenverCamaroGuy
What would that show me? It really sounds mechanical but I havent worked on an engine this advanced.
Old 03-18-2019, 11:27 PM   #5
DenverCamaroGuy
I have read alot about the fuel pumps and injectors being noisy. This is extremely loud and audible inside over the radio. I wish I could post the video I made.
Old 03-19-2019, 04:47 PM   #6
gringo
gringo's Avatar
Drives: Camaro V6
Replace the coil on that cylinder and see if it goes away. Maybe the coil is going bad or something.
gringo is offline   Reply With Quote
Old 03-19-2019, 10:57 PM   #7
DenverCamaroGuy
Update
Well guys thanks for all the replies and tips, unfortunately we pretty much just confirmed the worst case scenario, it has a rod knock. However I have been doing some research and while I will be rebuilding that engine I will also be doing a few performance upgrades. Had a few people me I should l99 or LS3 swap it but it seems like that isnt very easy or cost effective so performance V6 it is.
Old 03-19-2019, 11:13 PM   #8
spyderbuddy
me too
blown head gasket, going to do some mods
3.6l v6, knocking, lifter noise, rebuild
