#Camaro6
Go Back   CAMARO6 > Engine | Drivetrain | Powertrain Technical Discussions > V8 LT1 Engine, Exhaust, and Bolt-Ons
BeckyD @ James Martin Chevy
Old 03-20-2019, 10:52 PM   #1
Silver2ssA8
Drives: 2017 Silver SS
Intake manifold torque question
Just installed a ported intake manifold and throttle body, did the work last night and used blue thread locker. I torqued the manifold in sequence and in stages with the motor cold and then took it for a spin. I came back and let it sit for 30 minutes and rechecked torque, I got a few turns out of each bolt to reach 89 inch pounds again. Is it bad to torque the manifold with a hot motor or could they really back out in a couple miles?
Thanks for the help!
Silver2ssA8 is offline   Reply With Quote
Old 03-25-2019, 11:36 AM   #2
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
Here's my best guess: the thread locker had not hardened before your drive and the heat reduced its viscosity even more- to the point it acted a bit like a lubricant, decreasing the resistance/friction on the threads. This allowed you a few more turns while still staying in "spec".
If you don't get a CEL next start up, you're probably a bit tight but O.K.
