Old 03-22-2019, 05:43 PM   #1
LucasBest
Lucas
LucasBest's Avatar
Drives: 2014 LS
Remove Front Bumper Side Brackets
Hi,
I purchased a new front bumper for my 2014 LS and the passengers' side attachment bracket was broken pretty badly in shipping. I also want to remove it anyway before I get the bumper painted. I thought the brackets were simply attached with screws but it looks like it's some kind of through-hole pin.
Anyone have any advice on how to get the bracket removed? I attached a picture of the bracket.
Thanks!
LucasBest is offline   Reply With Quote
Old 03-23-2019, 09:13 AM   #2
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Probably a rivet that will have to be drilled.
Orange Krush II
Old 03-23-2019, 11:21 AM   #3
LucasBest
Lucas
LucasBest's Avatar
Drives: 2014 LS
Oh interesting, are the rivets still usable after removing them or will I need to get new ones?
Do you happen to have any advice on how do remove/replace the rivets, this will be a new one for me.
Old 04-12-2019, 09:29 AM   #4
Turbo_J89
Drives: 2015 BVM Camaro 1LE (2SS/RS)
The rivets aren't reusable. You have to drill them out. You install the replacement rivet with a rivet gun for metal rivets. The rivet gun is about $25-$35 depending on which you go with.
Turbo_J89 is offline   Reply With Quote
Old 04-12-2019, 10:47 AM   #5
swampcritter
Drives: 2014 Camaro LS / 13 zl1
Theres 4 rivets holding it on.I have a 14 LS and happen to have the cover off also.You are going to have to remove the black trim that runs across the center also ,there is a rivet under it too
swampcritter is offline   Reply With Quote
Old 04-12-2019, 09:29 PM   #6
Turbo_J89
Body shop painted that bracket that's broken on yours without asking me so I'll be doing this too.
Old 04-25-2019, 05:47 AM   #7
Turbo_J89
Have you purchased a replacement bracket yet? If so, what's the part number?
bracket, front bumper, removal
