pat murray
Drives: 2011 camaro 2 ss red jewel Join Date: May 2013
Rps twin disc clutch and flywheel for sale
Rps twin disc clutch and flywheel rated to 1200 hp for sale . Perfect condition removed when putting car back to stock. $750
![]() Drives: 2010 2SS/RS & 2007 2500HD D-Max Join Date: Dec 2014
how are street manners with this clutch? does it require a different slave?
2010 Summit white SS/RS, Manzo full exhaust w/2" primaries, Roto-Fab intake, FE4 conversion, JRI Coilovers built by Ult_Performance w/hypercoils, BMR sway, BMR trailing arms, UMI toe links, solid sub-frame bushings, upper control arm bushings, radius inserts, caster locks, Taylor wires, BTR spec'd cam, tuned by ECS, various little lighting mods, ebay SLP splitter, Heritage grille, ZL1 rockers, Apex 19x11 w/RE-71r's 305/30/19, eaton tru-trac
2007 2500HD Duramax, Built trans, custom tuned beast |
pat murray
A touch harder pedal but barely and it uses stock slave .
![]() Drives: 2015 2SS 1LE Twin Turbo Join Date: Jun 2018
Is this the carbon-carbon option...?
![]() ![]() ![]() ![]() Drives: 2015 1LE Join Date: Oct 2015
Just curious what that set up weighs?
2015 1LE, TSP 225/236 113+3, VMAX Throttle Body, CAI with race scoop, GPI Ported Intake, Land Speed Stage 2 Heads, 1-7/8 headers, NPP exhaust, 25% Fluidampr, LT1-S Monster Clutch, 485 RWHP & 444 TQ
#6 |
![]() Drives: 2010 Camaro SS Join Date: Oct 2013
Part Number?
#7 |
GPI Sales Consultant
Do you have the part number by any chance?
Got a question about a GPI product? Feel free to shoot me a message! |
#8 |
![]() Drives: 80 Z28 - 93 Z28 - 14 Camaro SS-RS Join Date: Sep 2016
Wondering part number and is it complete? I want to upgrade my stock clutch but I am new to the 5th Gen. I assume I can re use my 30K throw out bearing you said you use the stock one. Is there anything else I would need if I bought this
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS/RS Join Date: Mar 2014
RPS clutch
Do you know the weight? I can see it's got all carbon rings
Also how many miles?
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
#10 |
pat murray
I don't have the part number. It works with the stock throw out bearing and it has about 2000 miles on it.
#11 |
pat murray
Not sure on the weight I will see if I can find it on their site
#12 |
![]() Drives: 2010 Black SS Full Bolt ons Join Date: Mar 2018
Still available?
