Old 03-23-2019, 02:54 PM   #1
bleibert
Drives: 2010 Camaro RS 2LT
Thumbs down 2010 2LT V6 MPG Dropping
My Camaro used to get really good gas mileage but has been dropping and dropping to now only getting 18mpg blended. What can I check or service to get somewhere near a few years back? Closer to 23mpg?
bleibert is offline   Reply With Quote
Old 03-23-2019, 03:23 PM   #2
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
What is "blended"?
Rock-It Man is offline   Reply With Quote
Old 03-23-2019, 04:13 PM   #3
bleibert
City/highway
Old 03-23-2019, 04:26 PM   #4
Leo72793
Drives: 2011 2SS/RS
Tips:
1. Stop flooring it
2. change your air filter
3. Use better gas,
4. tire pressure/alignment check
5. clean the intake valves (not quick) blame direct injection
•2011 Camaro SS 2SS/RS A6
•MRR M017 1le Replica Wheels
•Vararam Ram Air Intake
•Speed Engineering Longtube Headers w/ Magnaflow HF Cats
•Bo White PnP Stage 2 TB
•GPI SS2 VVT Cam w Cometic thin gaskets 10.69 compression
•Xpipe w/ Res Delete and NPP Exhaust
•Tuned By Anonymous Calibrations
•Gen5DIY Mylink Conversion W/ Backup Cam
•Morel 3 way custom speakers, Infinity 860w Subwoofers in trunk baffle
•Helix P6 6ch amp w/ 8ch DSP and P1 Sub amp
Leo72793 is offline   Reply With Quote
Old 03-23-2019, 05:53 PM   #5
xstuntman
Drives: 2012 Victory Red LFX
How many miles on the car?
'18 SS wheels, colored matched Heritage grille, actual driving lights, ZL1 strut tower brace, GM Performance billet aluminum fuel door, victory red rotors and calipers, 1/4 window American flags, splash guards, AEM dry panel air filter, Hot Wheels steering wheel and seat covers, Hot Wheels exterior emblems.
xstuntman is offline   Reply With Quote
Old 03-23-2019, 08:52 PM   #6
ChibiBlackSheep
ChibiBlackSheep's Avatar
Drives: 2012 2SS/RS, 1968 SS
Pull a plug or two and make sure they aren't completely covered.
I noticed that I was running rich for a little while, and then my high-pressure fuel pump went in the engine. Then it was just dumping fuel through it. It was not a cheap repair.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS
ChibiBlackSheep is offline   Reply With Quote
Old 03-24-2019, 11:34 PM   #7
Pro-tuned
Angewendet Ingenieur
Pro-tuned's Avatar
Drives: 14 Camaro ZL1
Check your 02 sensors.
LQ9, Iron Block, Forged internals, 408CI, Jannetty custom cam, TS short block, Whipple, Hardened Jackshaft, PRC 260, 2X3 Dynatech Full Competition, HF Cats, CAI, NW 103, Chee, ID 1300, COPO Breather, MSD, Fore Dual Pump, ultratorque, E85, dual Meth, True Trac, 3:45, 1500hp axle-shafts, DSS CF, BMR, custom Pearl/Candy paint by Jaidah.
Pro-tuned is offline   Reply With Quote
Old 03-25-2019, 07:25 AM   #8
Rock-It Man
Originally Posted by Rock-It Man View Post
What is "blended"?
City/highway
LOL. I thought you were talking about blended gas.
You're not buying E85, are you?
Old 03-25-2019, 10:44 AM   #9
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 SW 2LT/RS LFX/AY6
Starting to wonder if I'm having a similar issue. I don't think the car is running richer than normal but my gas mileage is awful (like OP, used to average over 22, now I barely get 24 on the highway it seems).
Any other symptoms to look for? I could data log but I don't know how to read it. lol
DSX_Camaro is offline   Reply With Quote
Old 03-25-2019, 11:20 AM   #10
ChibiBlackSheep
It's honestly very easy to pull plugs on these engines. I would pull 1 from each bank to make sure they aren't completely black, and monitor oxygen sensors data.
Here's what my plugs looked like versus the new ones I put in, when I was having the issue with the fuel pump:
Old 03-26-2019, 11:27 AM   #11
TooCool5
TooCool5's Avatar
I have been running this LLT close to 10 years. I always loose mileage when they come out with the winter gas formula, then it messes up your fuel tables even into the spring.
Here is how to get it back.
1) Always run top tier fuel.
2) Pull fuse 5 & 20.
3) Clean throttle plate and mass air flow sensor (special CRC cleaner)
4) Put fuses back in and watch mileage go back up.
I can do 33-34 all highway on summer fuel.
fuel, gas, gas mileage, mpg, mpg fuel economy
