Old 04-01-2019, 11:02 AM   #1
jethrobandit
jethrobandit's Avatar
Drives: 2013 Black 2SS
Engine Knock in 6th Gear
I'm chasing an issue I can't seem to figure out. When cruising on the highway, dropping it into 6th gear I get engine knock when I try to accelerate. Usually that's between 1800-2200 RPM in 6th trying to accelerate. That is the ONLY time I get any kind of knocking in the engine. I've only ever put in 93 and have pulled the fuses a few different times to ensure its reset.
I have a BTR stage 3, LT, cold air, catch can, and of course a tune to go with the cam and LT install. I'd take it back to the guy that tuned it, but he went out of business (not for bad work... but that sucks). I've also tried octane booster in a couple tanks, but doesn't seem to help. Has a strong MAF according to the codes and have cleaned it.
Not sure what else to try other than finding another tech who can check the tune and potentially update it. Just not many options in my neck of the woods.
jethrobandit is offline   Reply With Quote
Old 04-01-2019, 02:40 PM   #2
Nb1081
Drives: 10 2ss/rs
does noise go away when u push clutch in in 6th gear
[/SIGPIC]10 2ss ls3 sw long tubes,cai intake,phastek scoop,se3" exhaust,elite e2, bw stg2tb, tsp f35, motive 4.10 lpw cover, 15" conversion, 510whp tuned by john donovan
Nb1081 is offline   Reply With Quote
Old 04-01-2019, 06:22 PM   #3
jethrobandit
Yes. And it isn't there when holding a speed (65-75) at 1800-2200 RPM. It only happens when I try to accelerate from that range in 6th. Accelerating from that RPM range in 5th or lower, it doesn't happen.
To me it's always sounded like knock from bad gas or something. But, I've never put in below 93 and have tried other steps to try and fix it. Only has 42k miles on it.
Old 04-02-2019, 08:30 AM   #4
gtstorey
I've heard good things about DBR Performance in Spring Hill.
Old 04-02-2019, 08:30 AM   #5
Nb1081
Drives: 10 2ss/rs
Its not your motor its your tranny might b able to save rest of it if you get it fixed right away and till then leave it out of 6th you now have a 5 spd. Now this is just my opinion on what you have said your issues are i would also if your not sure try n get on lift and run through gears to 6th and look and listen, but seeing as its only in 6th im going with tranny
Old 04-02-2019, 11:57 AM   #6
jethrobandit
I have too, just hard to find a good time to get down there and ask questions. It's over an hour away. But may have to do it just to get it retuned.
2013 2SS ::: MiSSy
BTR Stage 3 :: GM 3.91 :: Eaton TrueTrac :: SW LT Headers :: Elite Catch Can :: CAI :: ADM Cold Scoop :: VMAX ported TB :: Forza 3Way :: BMR Lowering Springs/Toe Rods/Lower CA/Trailing Arms/Subframe Bushings
Old 04-02-2019, 11:59 AM   #7
jethrobandit
Thanks. Not something I would have considered an issue to this point. Hoping I don't have move that ahead of all my other performance upgrade stages.
2013 2SS ::: MiSSy
Old 04-02-2019, 06:50 PM   #8
1LEric
Drives: 2015 Camaro 1LE
Try downshifting for your engines sake . You are lugging the engine.
1LEric is offline   Reply With Quote
Old 04-05-2019, 09:30 AM   #9
jethrobandit
I'm talking about doing 70-80 MPH on the highway in 6th and barely pushing the pedal to accelerate 2-3 MPH to pass someone on the left. Or even having it on cruise control at those speeds and going up a hill. Those are not scenarios for downshifting.
2013 2SS ::: MiSSy
Old 04-05-2019, 10:04 AM   #10
xc_SS/RS
Drives: 2010 Camaro SS/RS
Can you datalog and or tune it yourself?
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
engine, knock, octane, tune
