Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Members Classifieds - Parts for sale or wanted > Suspension / Chassis / Brakes
Old 04-02-2019, 02:23 AM   #1
1badchicken
1badchicken's Avatar
Drives: 2015 Camaro SS 2SS Green Flash
Custom C7 Z06 vented 6 Piston Upgrade
I am selling my Camaro and will begin de-modifying it this week in order to sale or trade it in.
The system contains the following items and you will only need to re-use your current rear rotors to make this a complete kit. This set-up cost over $2400. It has less than 500 miles on this system and is as new.
$1750+Shipping
GM 2015-19 Chevy Corvette Z06 Front Brembo 6 Piston Calipers $800
2010-2015 Camaro SS Brembo 4 Piston Brake Rear Calipers $400
GM OEM Front 2 Piece Rotor Pair Brembo $600
TPH Coatings Cyber Gray Metallic -$425
Ceramic Brake Pads-100% pad life remaining
F/R Goodridge steel lines $160
I am located in Southern California and prefer a local pick-up but will ship
1badchicken is offline   Reply With Quote
Old 04-02-2019, 10:46 AM   #2
MrEous
MrEous's Avatar
Drives: 2012 SC'd SS
So tempting...what backing plate is needed for the front? ZL1 backing plates?
MrEous is offline   Reply With Quote
Old 04-02-2019, 02:50 PM   #3
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
You can trim the 4 piston caliper shield.
Orange Krush II
Old 04-02-2019, 02:58 PM   #4
1badchicken
They have the AC Delco ZL1 backing plates
Old 04-02-2019, 05:50 PM   #5
1badchicken
This is one modification that surely gets a lot of attention on top of the increased braking power
Old 04-02-2019, 06:30 PM   #6
GMteSSted
GMteSSted's Avatar
Drives: 2018 ZL1 1LE
Do you have any pictures installed?
Any estimate on what the shipping will cost going to the east coast?
GMteSSted is offline   Reply With Quote
Old 04-03-2019, 12:49 AM   #7
1badchicken
I will take some tomorrow and post them
If you can PM your zip code I’ll find out
Old 04-03-2019, 08:41 PM   #8
1badchicken
With this style of wheel it’s difficult to capture on photos. Keep in mind I have 21 wheels. If you haven’t held a 6 piston caliper, it’s huge compared to the SS brembo
Old 04-09-2019, 08:09 AM   #9
SavageSS
SavageSS's Avatar
Drives: 2016 Camaro SS
Pm sent
Sent from my SM-G955U using Tapatalk
2016 Black M6 2SS - NPP, MRC
MRR M017 1LE Replicas, Rotofab CAI
ARH 1 7/8 LTs w/ cats
Pray ported MSD Atomic AirForce Intake Manifold + TB
BMR upper/lower trailing arms and upper control arms
Pray Tuned + E85 (490WHP)
SavageSS is offline   Reply With Quote
