04-07-2019, 01:59 PM | #1 |
Drives: 2013 Camaro LS Join Date: Jan 2017
Debadging Question
What is the easiest way to debadge this Chevy Logo that is on the trunk?
Are there holes under it? I heard a hair dryer will bubble the paint. Is this true? Thanks so much |
04-07-2019, 02:19 PM | #2 |
Drives: 2015 Z/28, 2015 1LE Join Date: Feb 2017
I'm not sure about the holes, I cant remember when they switched it to just adhesive. But I just replaced mine with a black one. I used a heat gun on low to just get things soft, then a plastic pry tool to get under it and lift it. Then I used some floss to help cut through a little more. Although I think fishing line is better but I did not have that. Then I just had to pull pretty hard to peel it off. The adhesive stuck to the car and not the badge. But when I peeled that off, the adhesive came off in one piece which was nice. Took me about 10 minutes
04-07-2019, 02:25 PM | #3 | |
04-07-2019, 02:29 PM | #4 |
Drives: 2013 SS 1LE Join Date: Nov 2011
Low heat on hair dryer and fishing line....easy..peasy !!!!
04-07-2019, 02:35 PM | #5 |
Drives: 2015 LT RS Camaro, 1978 Trans Am Join Date: Jan 2017
just like they said
Just like DBHWT said, hair dryer on low and fishing line comes off very easily.
if any adhesive left use some isopropyl alcohol or WD40 and you are done!! |
04-07-2019, 02:37 PM | #6 |
Started#gottalovethatblue
Low heat, don’t sit too long on one spot, take your time. You can try and pry it or use dental floss. The holes were on 2010 cars.
04-07-2019, 02:41 PM | #7 |
04-07-2019, 02:55 PM | #8 |
Drives: 2011 Green SS M6 Join Date: Jun 2015
Yes
Edelbrock EForce Blower, RDP custom grind cam with upgrades,Stainless Power Headers with HighFlow Cats, Stainless Power Retro catback, DSS halfshafts, CAI brand CAI, Tuned ON the Dyno by Steve at RDP. SLP rims,All vinyl stripes removed and painted on, custom hand painted pinstriping, Custom leather seats, Lloyds mats,windows tinted, Sparks emblems, Hurst Billit shifter, and too many small items to list. VDI Scissors doors.
04-07-2019, 03:12 PM | #9 |
Ret AF, cancer survivor
Drives: 2013 Camaro 2SS/RS & 2006 Corvette Join Date: Jul 2015
Have removed, modified or replaced just about every badge on mine. As other's have said, hair dryer on low and thin fishing line work great. Once I get one started, I also squirt a bunch of Goo Gone behind it to help soften up the adhesive; I also use it to clean off any adhesive residue left behind after removing the badge.
04-07-2019, 04:44 PM | #10 |
Drives: 2013 Camaro SS Join Date: Oct 2016
Mine is a 2013 and there are holes behind it, I don't remember how many or where. I put the oracle lighted bowtie on and in order to run the wire it required a hole that I don't remember drilling.
04-07-2019, 05:15 PM | #11 |
Really? Has your car ever been in a wreck or had the trunk replaced for some reason? I was certain that the holes were only on 2010's.
04-07-2019, 05:54 PM | #12 |
Fast Cars and Old Guitars
Drives: 2015 2SS RS (L99, baby!) Join Date: Apr 2012
You paid a lot for that logo. Fly it proudly!
04-07-2019, 10:03 PM | #13 |
Ponies are for girls
There are two holes. I had mine done at the shop when i got my defuser replaced after an altercation. I'd use fishing line and get the gasket/silicone cut until you get to the two holes and see if you can pull it out. Otherwise, see if you can access it from inside the trunk lid.
H&R 1.8/1.7” drop, Overkill 80mm + intake ported by AFS, 1" insulator MACE, Accel Super Coils, THR cai, JET MAF sensor, Hurst shifter handle, GPP strut tower brace, CI ice cube tray hood vents (functional) @SemperFiCamaro
04-08-2019, 07:14 AM | #14 |
old school chevy rodder
A sparks restoration billet SS badge fills the spot nicely though its not cheap it does make a nice handle for the trunk lid.
2021 Wild Cherry ZL1 A10, Sunroof, Data,Red Carbon Interior, Nav, RotoFab Big Gulp , Elite x2ultra, Borla ATAK, Driveshaft shop, full BMR susp, Speed eng. valve covers, intercoolers, ATI , 2650 MAG, DSX lid, 103 NW, JBA shorties, Lingenfelter check, 1le wheels, spoiler and diveplanes, PCV, Big3racing ice tank, [SIGPIC]etc....
