Old 04-07-2019, 06:35 PM   #1
Maroon 6.2L SS
Maroon 6.2L SS's Avatar
Drives: 2010 Camaro SS A6
Tire pressures cold/hot
Little confused on this. I understand that tire pressure rises 3-4psi when they get hot after driving on a hot day for a while or doing a burnout and then a run down the dragstrip.
My question is:
If my tires are cool, say the car has been shut off for some time, and the tire pressure reads 20psi on the drag radials, and then I immediately heat them up on a burnout and take a run down the strip and they worked the best at this original cold psi setting, what do you do when you get back in line and are immediately up next? They now read 23-24psi because they're hot? Do you leave them like they are or do I lower them back down to 20psi right before the run?
I hope this makes sense!!!
Maroon 6.2L SS is offline   Reply With Quote
Old 04-22-2019, 12:11 AM   #2
ihada69L78
ihada69L78's Avatar
Drives: 2023 Silverado LTZ, 2022 Camaro 2SS
Originally Posted by Maroon 6.2L SS View Post
Little confused on this. I understand that tire pressure rises 3-4psi when they get warm/hot after driving on a hot day for a while or doing a burnout and then a run down the dragstrip.
My question is:
If my tires are cool, say the car has been shut off for some time, and the tire pressure reads 20psi on the drag radials, and then I immediately heat them up on a little burnout and take a run down the strip and they worked the best at this original cold psi setting. What do you do when you get back in line and are immediately up next? They now read 23-24psi because they're hot? Do I leave them like they are or do I lower them back down to 20psi right before the run?
Lower them back to 20psi before each run.
Currenent rides:
2020 SW ZL1 A10
2019 SW 2SS A10
2017 SW Silverado LTZ
ihada69L78 is offline   Reply With Quote
