04-11-2019, 08:09 PM | #1 |
Redline for trans and diff, need some help
I've decided to go with Redline for both trans and differential. Just looking for exact grades to buy. I trust the help here better than some salesman may give me.
04-18-2019, 09:26 AM | #2 |
Drives: 2014 1SS 6M Join Date: Dec 2018
I've been running Redline fluids for years in my 4th gen with great results. I just swapped out the transmission and differential fluids with Redline in my 2014 1SS on Saturday. It really helped with how notchy the shifting had become. I'll be running at Sebring tomorrow and Saturday so I'll let you know how it goes.
Redline D4 ATF https://www.summitracing.com/parts/red-30504 Redline 75W90 GL-5 Gear Oil https://www.summitracing.com/parts/red-57904 |
04-18-2019, 09:43 AM | #3 | |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
No need for friction modifier with the gear oil. Comes premixed
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
04-18-2019, 12:20 PM | #4 |
Drives: 2015 SS/RS 1LE Join Date: Dec 2014
You have a few options with the trans fluid. You can use D4, MTL or 50/50 of the two depending how and what temp you drive in. I did the 50/50 and noticed a improvement over the factory fill. But on those 80 degree days the fluid felt too thin, and that is usually when I drive my 1le hard. I will be going straight MTL this summer. Here is a link with some info;
https://www.camaro5.com/forums/showthread.php?t=374798 |
