![]() Drives: '15 Silverado LTZ & '13 ZL1 ragtop Join Date: Nov 2016
Best launch pressure for NT05R?
What's the safest lowest psi anyone here has used on a non-bead locked rim? I plan on launching in 2nd gear with the nannies off with a 2 step. Currently about 700 rwhp and 3600 rpm stall.
![]() Join Date: Apr 2014
You can try as low as 18-22psi. If the tires are low profile don't go too low., what size are they? Start around 26psi hot and drop 2-4 psi each time and try again.
Sent from my Pixel 2 XL using Tapatalk |
The 18" profile equivalent of the OEM 20" tire.
GPI Sales Consultant
I hit my 305/45/18 NT05R's at 18psi and they seem to like it there. I'm not sure they will tolerate much lower.
Got a question about a GPI product? Feel free to shoot me a message! |
Steve
Drives: 2014 ZL1 Vert Red & 2012 ZL1 Black Join Date: Sep 2014
I've been running 17 PSI in the Nitto NT05R drag radial 315/35R20 tires. It did 11.859 seconds at 120.08 MPH and several 11.9 runs in my manual ZL1 with 644 rwhp. The car does 11.407 at 122.6 MPH with Hoosier Drag Slicks 28x10-17 D06 at 15 PSI.
#6 |
Drives: 2013 Sparkly Red One Join Date: Dec 2018
I had 305/45/18 NT05R for a while and found 18 psi was my sweet spot.
Do yourself a favor and get a set of 17s. |
#7 |
![]() ![]() ![]() ![]() Drives: 2013 ZL1 and 2019 Ram Laramie Join Date: May 2017
#8 |
