Old 04-14-2019, 08:00 AM   #1
belkjamesr
Drives: 2013 2SS RS 1LE
Do long tube headers delete cats?
Buying a 2013 SS that has long tube headers and I’m told it has the first set of six cats deleted but doesn’t throw codes. Is this true?
belkjamesr is offline   Reply With Quote
Old 04-14-2019, 08:10 AM   #2
Rons1le
Rons1le's Avatar
Drives: 2015 Camaro 2SS RS 1LE AGM
Not usually with out a tune. But if they put the defouler bungs in they say they don't throw codes but your not getting a true reading that way.
Sent from my SM-G960U using Tapatalk
2015 2SS RS 1LE NPP/w Kooks headers, Procharged, ID1050X injectors, Katech belt tensioner, Mighty Mouse Catch Can, BMR subframe connectors, Matco driveshaft loop, AEM Wideband/Boost/Fuel gauges , Z/28 Splitter and Spoiler/w Wicker bill, Power Stop rotors and brake pads, MRR Z/28 Rep Wheels 20" w/p zeros 285 fronts and 305 rears, ZL1 addons Rock guards and Tow hook, Rear window louvers, Flags on the quarter windows and the moonroof, Billet aluminum door handles.
Rons1le is offline   Reply With Quote
Old 05-08-2019, 02:44 PM   #3
The_Raging_Bull
Raging Bull Reborn
The_Raging_Bull's Avatar
Drives: '09 CGM Z063LZ '15 RH Z/28 #0631
typically they can be ordered with or w/o cats. a tune is required to ignored th eo2 sensors. As ron said, otherwise the engine throws a code.
Toy 1 '15 RH Z/28 w/AC & Radio S/N 0631
Toy 2 '09 CGM Z06 3LZ
My DD: '17 Ford Mustang GT
Her DD: '14 F150 Ecoboost 3.5
The_Raging_Bull is offline   Reply With Quote
Old 05-08-2019, 02:55 PM   #4
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #832
First off, there's only 4 cats on a 5th gen Camaro. Secondly, you can get high flow cats or go catless with long tube headers. As others have said, you will need a tune otherwise the car will throw a CEL.
Guessing as this thread was started mid April and it shows you now drive a '13 SS 1LE, I assume you bought the car? How do you like it?
Check out my build thread
