Old 04-14-2019, 05:43 PM   #1
Maroon 6.2L SS
Maroon 6.2L SS's Avatar
Drives: 2010 Camaro SS A6
Replacing belts
Looking into replacing the belts. Can anyone recommend a good set of belts? AC Delco? I believe it's just 2 belts correct? A/C belt and Serpentine belt or am I wrong? Thanks!!!
Maroon 6.2L SS is offline   Reply With Quote
Old 04-15-2019, 05:37 AM   #2
JoelNR
King of the Lurkers
JoelNR's Avatar
Drives: 2010 SS/RS (Victory Red)
I've always used Gates if I can't get an AC Delco. Never had any issues. Both are high quality products.
Yea you should only need 2 of them. One for the main accessories and another for the AC.
'10 SS/RS M6
The go:
ESS supercharger kit, Speed Engineering headers, NGK TR6IX plugs, ZR1 MAP sensor, DSS driveshaft, BMR trailing arms & toe rods.
610 HP/556 TQ. Tuned by Ryan at KC Maxx Performance.
The less important bits:
MRR 228s, SLP front lip, ZL1 grille (no bowtie), Z28 spoiler with ZL1 Addons wickerbill, RPID tow hook, Sparks Restoration SS trunk emblem, ZL1 rear & Phastek front rock guards.
JoelNR is offline   Reply With Quote
Old 04-15-2019, 01:55 PM   #3
granatl
granatl's Avatar
Drives: 2SS RS ABM A6
Main serpentine is easy, A/C is a PITA. They provide a little guide tool to help. Make sure to cut the old A/C belt -- there's no point in even trying to keep it if you're already committed to changing it.
Jack Bilger
granatl is offline   Reply With Quote
Old 04-15-2019, 02:14 PM   #4
zlathim
zlathim's Avatar
Drives: 2010 Camaro 2SS/RS M6
This is the tool you need to install the AC belt.
https://www.amazon.com/Gates-91030-E...43508305&psc=1
GPI SS2; EE E2 catch can; SP 1 7/8" LT Headers w/ hfc; FM AT 3" cat-back; CAI Cold Air Intake; AEM Wideband
Tuned by GPI
McCleod RXT; MGW flat stick; Ram Clutch slave cylinder & hydraulic adjuster
BMR cradle & diff bushings, trailing arms, toe rods & upper control arm bushings
Hotchkis sub-frame brace
Stop Tech Z-23 brakes
4.10 gears, Eaton Truetrac, LPW diff cover
Best 1/4 mile 12.073 @ 115.68 mph 3,300 ft DA
zlathim is offline   Reply With Quote
Old 04-15-2019, 06:14 PM   #5
Maroon 6.2L SS
Thanks Gents!!!
