Old 04-17-2019, 01:30 PM   #1
Fvckenmuvenn
Fvckenmuvenn's Avatar
Drives: 2015 SS Camaro
Low Voltage Issues
Hello everyone, this is my first time posting on Camaro5, so i'm pretty oblivious to how this works. I apologize if I am not posting in the proper section. I have been browsing the forum for quite some time now, trying to see if anyone has come across the same issue that I am having. After recently supercharging my Camaro, I have been having voltage issues. My 2015 SS Camaro use to show between 13.5-14.2 on the voltage display, but it dips as low as 11.0 volts now. The battery is original, so I went ahead and started with that. I am still having issues. I thought it may be possible that the alternator is going out.The other day, the car went into "batter saver" mode, which I have never seen before. Some days the voltage is good, other days it drops so low that I cannot start the car without a jump after I shut it off. My best guess is that the alternator is failing and drawing power from the battery, but I honestly have no clue. Any thoughts or advice on this would be greatly appreciated. Thank you!
Fvckenmuvenn is offline   Reply With Quote
Old 04-17-2019, 01:34 PM   #2
gtstorey
Belt Slip?
Old 04-17-2019, 01:37 PM   #3
Fvckenmuvenn
Originally Posted by gtstorey View Post
Belt Slip?
No belt slip. I checked all grounds as well. I'm not sure what's going on. Never had an issues prior to supercharger install. I thought maybe the damper and extra pulley may be putting more load on it, but I honestly don't know much about this stuff :(
Old 04-17-2019, 01:44 PM   #4
Benman
Benman's Avatar
Drives: 13 IOM 2ss RS manual
Sounds like a ground wire or other connection was either not reinstalled correctly or missed entirely. Check at the battery with a multimeter with the car running, should always have 12.5 or higher while idling, regardless if factory accessories turned on or off.
Benman is offline   Reply With Quote
Old 04-17-2019, 01:50 PM   #5
Fvckenmuvenn
Originally Posted by Benman View Post
Sounds like a ground wire or other connection was either not reinstalled correctly or missed entirely. Check at the battery with a millimeter with the car running, should always have 12.5 or higher while idling, regardless if factory accessories turned on or off.
I'll go over everything again when I get a chance and check the battery with a multimeter. Thanks for the help. Ill update once i've done that!
Old 04-17-2019, 03:17 PM   #6
granatl
granatl's Avatar
Drives: 2SS RS ABM A6
Check the ground that goes from the passenger-side head to the frame. Both ends have to be tight/clean
Jack Bilger
granatl is offline   Reply With Quote
Old 04-17-2019, 04:34 PM   #7
Fvckenmuvenn
Thanks everyone. I went back over everything and it ended up being the ground wire for the alternator
Old 04-17-2019, 05:45 PM   #8
Welker2
Ret AF, cancer survivor
Welker2's Avatar
Thank you for posting that you found the issue, what it was and that you fixed it. Way to many people neglect to do so.
Old 04-17-2019, 06:03 PM   #9
Fvckenmuvenn
Originally Posted by Welker2 View Post
Thank you for posting that you found the, what it was and that you fixed it. Way to many people neglect to do so.
No problem. I appreciate all of the help from everyone!
Old 04-18-2019, 08:12 AM   #10
Benman
Benman's Avatar
Good deal, glad you were able to resolve the issue. Enjoy the ride.
Old 04-18-2019, 04:53 PM   #11
PeteD
PeteD's Avatar
Drives: 2012 2SS Victory Red with white st
What up Jeremy????
PeteD is offline   Reply With Quote
Old 04-25-2019, 04:13 PM   #12
Fvckenmuvenn
Originally Posted by PeteD View Post
What up Jeremy????
Hey Pete!
Old 04-25-2019, 04:19 PM   #13
Fvckenmuvenn
So.. problem was "solved" for a couple of hours. All grounds still appear to be good. Alternator ground is still secure as well. The car pretty much runs fine when it wants to. I drove for about 20 minutes today and it stayed around 13.8v-14.1v. After shutting the car off for about 15 minutes and starting it back up, car was reading 12.3v. By the time I got home it was down to 11.7v. One thing I noticed is that the lume around the alternator ground looks pretty burnt up.
One last thing.. The car didn't act up like this until I dropped down to the smallest pulley on my supercharger, which is 2 sizes down from what I originally had. Forgive my ignorance, but could the smaller pulley be playing a part in voltage drop? Thanks again.
Old 04-25-2019, 04:36 PM   #14
gtstorey
Probably only if you got the wrong size belt and are getting major slippage.
alternator, battery, battery saver mode, voltage
