Old 12-05-2009, 03:15 PM   #1
Nate_687
Nate_687's Avatar
Drives: 2010 Camaro
Installing amp and subs - Where to run remote wire?
Ok, I am trying to install subs and an amp in my car.
I have a line out converter and know basicly what to do.
What I dont know is where to run the remote wire from my amp.
I mean i've had a little experience with car audio but its
been a while since i've hooked up subs and an amp to a
factory radio.
I dont have a factory amp so I cant tap into that, where should
I run it?
I just need to know the easiest place I could tap into.
Nate_687 is offline   Reply With Quote
Old 12-05-2009, 04:17 PM   #2
TonyNo
TonyNo's Avatar
Drives: 2016 2SS, SW
If you have no amp, then the easy thing is a speaker-driven relay to drive the remote line. Any car audio joint should have them. There are some LOC's that have them built-in, but you said you have one already.
TonyNo is offline   Reply With Quote
Old 12-05-2009, 04:21 PM   #3
Nate_687
Nate_687's Avatar
Drives: 2010 Camaro
Ok, thank you. I will check that out and see if I can get one.
Old 12-05-2009, 04:40 PM   #4
SummoneR
Paul
SummoneR's Avatar
Tie it into the white wire leading to the factory amp.
Old 12-05-2009, 04:58 PM   #5
BigBOSS
BigBOSS's Avatar
Drives: 2010 Camaro 1LT/RS, 6M, IBM
He said he didn't get the Boston Acoustics package, so no factory amp.
BigBOSS is offline   Reply With Quote
Old 12-05-2009, 05:32 PM   #6
SummoneR
Paul
SummoneR's Avatar
Oh wow I completely missed that! Thanks!
Old 12-05-2009, 09:58 PM   #7
Nate_687
Nate_687's Avatar
Drives: 2010 Camaro
yep, thanks for the replies.
No amp, if I did it would be alot easier.
I'm gonna try to get a speaker driven relay like TonyNo suggested.
Stereo GUIDE ALL READ WildBeast15 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 29 09-11-2010 01:14 AM
With this enclosure what subs and amp would you recommend? G.E. Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 2 12-03-2009 09:43 PM
subs and amp upgrade Wassert Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 8 02-22-2009 02:44 PM
