Old 04-21-2019, 10:37 PM   #1
MNCamaroGuy
MNCamaroGuy's Avatar
Drives: 2011 Chevy Camaro 2SS 6spd
Finished Heads and Cam Swap w/ mail order tune from TSP, but I'm running lean...
Hi guys,
I'm frustrated on this one. On Saturday I finished my heads and cam project, plugged in my new tune and everything worked great... For a while.
After about ten miles I got a CE light. I plug in my OBD2 reader and run through the three codes. The first was an intake air temp sensor 1 with high circuit input (P0113) and two codes for bank 1 running lean and bank 2 running lean (P0171 and P0174).
Is this a tune issue or is my IAT sensor causing it to run lean?
I had no issues prior to me doing the H/C job. I checked the MAF sensor with a multimeter and the resistance seemed normal and it responded to temperature changes. I also checked the pressure in the fuel system and it read at 30 psi. This seemed low but I'm not a sure exactly where about this should be.
Any advice would be greatly appreciated.
Thanks for reading, Jake
MNCamaroGuy is offline   Reply With Quote
Old 04-21-2019, 11:07 PM   #2
Athletics101
Athletics101's Avatar
Drives: 5th Gen L99
Man that sucks, this is way above my pay grade. There’s some smart guys on here they will point you in the right direction.
LSA conversion 2.5 upper 10% lower, L99 converted to LS3. TSP 229/244 cam, TSP LS3 ported and milled heads milled .015,Kooks LT’s no cats, Roto Fab, Borla arak cat back. 3200 stall,Forgestar F14 18’s and drag radials, pedders coil overs, BMR trailing arms & adjustable toe rods, mildly stripped Interior 685/613 on E 610/571 on 91
Athletics101 is offline   Reply With Quote
Old 04-22-2019, 12:39 AM   #3
ksmrz
ksmrz's Avatar
Drives: 2010 Camaro
Your maf has the iat in it. Seems like something is messed up with the tune. See if someone can't scan your fuel trims and intake air temp. I would say unplug the maf and see what your fuel trims are but I'd bet it's maf only and will be really rich at idle if the ve was never corrected
2010 2SS LS3 228/235 Cam Motion custom ground cam, AI 280cc ported heads, Dynatech 1 7/8" long tubes, catless mids, CAI intake, ATI 10% UDP, CORSA cat back, Slp 160 tstat, gm 3.91s/Tru trac, EFI LIVE tuned by myself
ksmrz is offline   Reply With Quote
Old 04-22-2019, 12:52 AM   #4
ksmrz
ksmrz's Avatar
Drives: 2010 Camaro
Should add it'll run ok maf only. If you have no vacuum leaks and 02s are working than the maf transfer or ve is off in the tune. As far as the intake air temp code. That's odd. Quite possible the wrong script was ran on your ecm?
Old 04-22-2019, 07:44 AM   #5
xc_SS/RS
Drives: 2010 Camaro SS/RS
Originally Posted by MNCamaroGuy View Post
Hi guys,
Check your grounds if everything was solid before you did the work. If those are all good you may have shorted something in the MAF or it's wiring
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 04-22-2019, 08:54 AM   #6
MNCamaroGuy
Thanks for the responses guys.
I will be looking into it some more today with the advice you've all given me and I'll pay an update if I get it resolved.
Old 04-22-2019, 09:57 AM   #7
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1
Should be around 55psi.
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
Badbubba is offline   Reply With Quote
Old 04-22-2019, 10:11 AM   #8
MNCamaroGuy
I just did a re-test of my fuel system pressure this morning with much better quality equipment and it read at 58 psi.
I trust that reading much more than the earlier 30 psi.
Old 04-22-2019, 11:14 AM   #9
PepeLePew
PepeLePew's Avatar
Drives: 2010 2SS Coupe; 2011 2LT Vert
I've had 2 separate case of lean conditions on 2 separate vehicles.
The first was due to to reinstalling intake manifold gaskets after a head swap that were not sealing correctly. The original gaskets sealed fine until I removed them and I failed to notice that they were bad (no longer raised) when I reinstalled them. That lead to a vacuum leak and lean conditions on both banks.
Most recently, I did a cam swap and put long tubes on my camaro. I failed to tie back the wiring harness that runs down the passenger side head and it was touching my header. After about 50 miles of driving, I got CEL with a bunch of codes:
Code Type Status Description
P069E PowerTrain Stored Manufacturer Defined
P2534 PowerTrain Stored Ignition Switch Run/Start Position Circuit Low
P0102 PowerTrain Pending Mass or Volume Air Flow Circuit Low Input
P069E PowerTrain Pending Manufacturer Defined
P080C PowerTrain Pending Manufacturer Defined
P2534 PowerTrain Pending Ignition Switch Run/Start Position Circuit Low
P0036 PowerTrain Permanent HO2S Heater Control Circuit
P0102 PowerTrain Permanent Mass or Volume Air Flow Circuit Low Input
P0141 PowerTrain Permanent O2 Sensor Heater Circuit
P0161 PowerTrain Permanent O2 Sensor Heater Circuit
Found out I had a melted harness and spent the next 3 days pulling it apart and soldering new wire in.
PepeLePew is offline   Reply With Quote
Old 04-22-2019, 08:06 PM   #10
MNCamaroGuy
Thanks for the advice. I've checked all of my wires and I've seen nothing that looks melted or cut, but you make a very good point with the vacuum leak. Tomorrow I'm going to look into that and the intake manifold. I'll keep you posted.
Old 04-24-2019, 06:46 AM   #11
STALKER
STALKER's Avatar
Drives: 2023 Camaro ZL1 1LE
What CAI are you running? Reason I ask is because after my build I had to go away from the Airaid CAI I was using. I was getting the same High IAT code and couldn't figure out why. Turns out the Airaid charge pipe which holds the MAF sensor was actually resting on top of the upper hose, which was causing the issue. I called Airaid and they said it was normal for there to be no gap.
I Swapped to a Z28 CAI, which has a 2" gap between the upper rad hose and the charge pipe......No issues since.
2014 Camaro SS Spring Edition LSX440ci
LSX Block, MAST 305 Black Labels, Exceldyne Valves, Diamond Pistons, Callies Crank & Rods, Cam Motion Cam, Johnson 2116LSR Lifters, Comp XDA Pushrods, Jesel Rockers, Mamo MSD, NW 102, Roto-Fab CAI, FAST 65# Injectors, ZL1 Fuel Pump, Kooks 2" Headers, Corsa Sport 3" Catback, Z28 Shifter, ZR1 Clutch, Katech LW Flywheel, 1LE 3.91 Diff, LPW Diff Cover, BMR - 1.4" Springs, LCA's, Trailing Arms, Toe Rods, Sway Bars, End Links, Diff Bushings, and Tunnel Brace, Z28/1LE Strut Tower Brace, Improved Racing Oil Cooler
2023 Camaro ZL1 / 1LE
Stock
STALKER is offline   Reply With Quote
