![]() Drives: 2011 LT Join Date: Mar 2014
Ways to quiet my exhaust?
I have a MRT v2 exhaust with a resonated X-pipe. I've enjoyed this setup for years, but now I'd prefer a more quiet ride. The drone at highway speeds really gets to me. Does anyone have any suggestions? Maybe J-pipes? Or a more economical alternative to Dynamat?
#2 | |
Captain Gingerbeard
Drives: 2012 IOM RS/SS 6MT Join Date: Mar 2013
Find someone giving away a stock exhaust?
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads. Quote:
![]() ![]() ![]() ![]() ![]() Drives: 2013 SW 2LT/RS LFX/AY6 Join Date: Feb 2013
J Pipes is probably the cheapest and easiest option.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
I Dynamatted the trunk floor pan and it helped with that long distance drone.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ |
![]() Drives: Camaro Join Date: Feb 2019
I've heard that dual x pipe does very well. Is there a person on the forum who has a dual x pipe?
