04-23-2019, 07:39 PM | #1 |
Drives: 2013 2ss Join Date: May 2011
New ECU question on 6 speed swap
Okay guys I'm kind of confused here. My car was automatic with fic 850 injectors and I have a BTR stage 3 Cam and so forth so far. Anyway make a long story short I converted from a automatic to a 6-speed tr6060... I already did the wiring inside and in the engine bay and already did the plate everything but I need to know. I know I need to tune the new ECU. My question is can I still drive the car with it 850 fic injectors with the stock ECU with no tune... not forever just for a couple days until my tune session comes available next Monday. And no I'm not going to Hot Rod it. Any feedback is wanted thank you
2013 auto ss..full bmr suspension..3800 stall...s475 turbocharger on 16 psi with 150 nitrous outlet plate...,BTR stage 3 turbo cam.....100% Methanol injection....LY6 6.0 iorn block ...
04-24-2019, 01:39 PM | #2 |
Drives: 2SS RS ABM A6 Join Date: Jun 2010
No. The LTFT's couldn't pull enough fuel for it to run. And there's a chance of hydrolock.
Let's say stock is 500 cc (IDK exactly) and you're running 850 cc. You have the ability to flow like 1.8x the amount of fuel over stock. So, the ECU "thinks" you have stock injectors, but you're really flowing 1.8x that. Bad situation.
Jack Bilger
