Old 04-29-2019, 11:17 PM   #1
makf22rap
Drives: 2014 Chevrolet Camaro 2SS Spring Ed
Shifter Rattle
I am having an issue on my 2014 2SS Spring Edition.Under any load and in any gear, I get this annoying rattle that doesn’t even go away with pressure on the shifter. I’ve taken it to several dealerships and get a different answer every time. One says it could be internal, one says possibly shifter bushings, and the other said it’s normal. I have it at a different Chevy dealership now because my warranty is only valid for 1 more week.
Funny how problems develop when the power train warranty is almost up.
The rattle isn’t especially loud, it can be droned out by the radio or by the windows being down, but it is extremely unnerving and I am wondering if anyone is having a similar problem?
makf22rap is offline   Reply With Quote
Old 04-29-2019, 11:19 PM   #2
SS 310H55A
Drives: 2014 Camaro SS
Maybe time to throw an mgw on that. Those stock shifters are garbage. I don’t get how Chevy can put such crap on these cars.
2014 SS | MGW Flat Stick shifter | Raceseng Slammer shift knob | Z/28 spoiler and grill
SS 310H55A is offline   Reply With Quote
Old 04-30-2019, 07:22 AM   #3
Camaro2ss2010
Camaro2ss2010's Avatar
Drives: 2010 Camaro 2SSRS M6
Mine does the same thing. Only at higher rpms though. Looked at everything I know to look at but can’t find the source.
Camaro2ss2010 is offline   Reply With Quote
Old 04-30-2019, 07:25 AM   #4
J Rod
J Rod's Avatar
Drives: '14 BRM 1LE 2SS/RS
x2! MGW is next on my to-do list
592 HP/590 TQ
LSA Blower w/ 2.45 Griptec, Reinforced Brick, FIC 1000 injectors, JRE FPCM, LFP Dual Pass HX, ZL1 IC pump, RotoFab CAI, Bo White TB, Coated Stainless Power 1-7/8" LTs, NPP, NGK TR7IX, Mighty Mouse Wild CC, AEM X-Series WB, Aeroforce Interceptor, MGW Shifter, Z28 Grill, Gary's Custom ZL1 Rockers, Hero Tails, Tuned by IMC
J Rod is offline   Reply With Quote
Old 04-30-2019, 08:32 AM   #5
pyroguy
Keeper of “THE list”
pyroguy's Avatar
Drives: ABM #832
If you're not willing to get a new shifter, I'd say it stays at Chevy until the source of the problem is found since you're still under warranty. No point in having them come back later with a solution to have it come out of your pocket.
Check out my build thread
Old 04-30-2019, 09:01 AM   #6
mbesman
Great White
mbesman's Avatar
Drives: 2015 Camaro 2SS
Maybe take off the shifter and spray it with dry lube in the linkage underneath the boot etc. This worked on the automatic shifter. Just spray it in there. It will leave a powdery residue which can be easily wiped but it shouldn't matter in your case since the shifter boot will cover it all up. The stuff is magic with these type of rattles.
mbesman is offline   Reply With Quote
Old 04-30-2019, 01:07 PM   #7
sscamaro
Drives: 2010 2SS, 2017 Silverado LTZ
I installed a Hurst Short Throw Billet shifter on my 2010 SS in December of 2009. It has been working great since with 62K miles on the car,
sscamaro is offline   Reply With Quote
Old 04-30-2019, 11:16 PM   #8
mbesman
Great White
mbesman's Avatar
Dry Lube I used
Old 04-30-2019, 11:36 PM   #9
Black 6.2L SS
Black 6.2L SS's Avatar
Drives: 2014 1SS/RS, LS3, NPP
Thanks!
Black 6.2L SS is offline   Reply With Quote
Old 05-01-2019, 12:19 AM   #10
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
I get a rattle at high rpms but only in 5th with my hurst short throw. The rattle wasn't there with the stock shifter.
camguynj is offline   Reply With Quote
Old 05-01-2019, 06:55 AM   #11
Wizard1183
Wizard1183's Avatar
Drives: ABM SS2/RS M6
Send a message via Yahoo to Wizard1183
But MGW shifters are much louder than stock. It’s probably the bushings. MGW as said is much better than stock. But you’ll hear road noise. Just a smoother shift.
Life is short, drive it like you stole it!
Wizard1183 is offline   Reply With Quote
Old 05-01-2019, 08:02 AM   #12
camguynj
camguynj's Avatar
Did you apply the Dynomat ?
Old 05-01-2019, 08:05 AM   #13
ZEN357
ZEN357's Avatar
Drives: 1991 Z/28 Convertible
I would install a Barton Shifter. Best mod I ever did.
ZEN357 is offline   Reply With Quote
2ss, camaro, manual, rattle, shifter rattle
