![]() Drives: 2010 camaro ss Ls3 376/480 Join Date: Sep 2014
376/480 HotCam
So I have a 2010 Camaro SS. I just replaced my stock L99 with a 376/480 hot Cam. I also added 1 7/8 Kooks long tube headers and 3" Kooks cat back exhaust. Car is tuned. This Saturday will be my first time driving it since I'm out of town right now. I can't wait. Does anyone else have this motor and if so, how do you like it and what else did you add? My SS will be enjoying a procharger next and I do plan on making some good quarter mile runs. Any ideas? Thanks for responding, you are appreciated.
weSS1LEy
Drives: 2015 camaro 2ss/rs/1le Join Date: Sep 2015
Paint looks amazing! What are the specs of that cam?
Rotofab, arh no cats, atak, elite cc, 94 octane tune, Mobil 1, phastek scoop, custom cam 230/243 .621 .604 114+4, related cam kit stuff. 470/435 rwhp/rwtq
Thanks brother. The cam has a 0.525 inch lift on the exhaust and intake side with 219 degree and 228 degree duration so the valves can stay open longer
Grumpy Grey-haired Guy
Drives: Camaro, Corvette & Merc C300(daily) Join Date: Aug 2014
Yup - that is a beauty of a Camaro. A friend has the 480 "hot cam" motor in his 2010 SS LS3 and it is quick. Very nice sound too, not too choppy.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '17 Corvette Grand Sport M7 Join Date: May 2012
If you're looking into a Procharger as the next mod, also look into some suspension, wheel and tire upgrades. As it is now, you're never going to get that thing to hook.
MY RIDE: 2017 CORVETTE GRAND SPORT--TRIPLE BLACK, 7 SPEED MANUAL, VARARAM TCR-7 INTAKE, BORLA CATLESS X-PIPE, CARBON FIBER STAGE 2 AERO, MGW SHORT-THROW SHIFTER
**SOLD**2011 TRIPLE BLACK SS CONVERTIBLE--6 SPEED MANUAL, MANY MODS, 455 RWHP/435 RWTQ DAD'S RIDE: 2012 ZL1 #1866--BLACK, 6 SPEED MANUAL, EXPOSED CF HOOD, POLISHED WHEELS, SUNROOF, ROTO-FAB INTAKE "Silly Americans, taking from the rich and giving to the poor only works in fairy tales. Success is earned here!". |
#6 |
Started#gottalovethatblue
I have to agree with DRKS1D3. I cammed my Camaro over the winter and especially if your tires aren't warmed up yet you'll look like a Mustang leaving a car show if you get on it too hard.
That being said, I think you're going to love the car. Don't forget some drag radials or possibly a drag wheel setup for the track. Good luck and post some times when you get back from the track and a video clip of the new mods!
#7 |
weSS1LEy
One thing though, I believe the hot cam is not a good supercharger cam due to its tight lsa. It’s 110 isn’t it? I would just rock it n/a as it is.
Oops it’s 112. Do prochargers work well with tight lsa’s?
#8 | |
![]() Drives: 2023 Camaro ZL1 1LE Join Date: Feb 2016
OP, I would think about your goals for the car. The last thing you want to do is just throw parts at it. You want to come up with a thought-out plan with a combination of parts that are proven to work.
2014 Camaro SS Spring Edition LSX440ci
LSX Block, MAST 305 Black Labels, Exceldyne Valves, Diamond Pistons, Callies Crank & Rods, Cam Motion Cam, Johnson 2116LSR Lifters, Comp XDA Pushrods, Jesel Rockers, Mamo MSD, NW 102, Roto-Fab CAI, FAST 65# Injectors, ZL1 Fuel Pump, Kooks 2" Headers, Corsa Sport 3" Catback, Z28 Shifter, ZR1 Clutch, Katech LW Flywheel, 1LE 3.91 Diff, LPW Diff Cover, BMR - 1.4" Springs, LCA's, Trailing Arms, Toe Rods, Sway Bars, End Links, Diff Bushings, and Tunnel Brace, Z28/1LE Strut Tower Brace, Improved Racing Oil Cooler 2023 Camaro ZL1 / 1LE Stock Last edited by STALKER; 05-02-2019 at 07:39 AM. |
#9 | |
#10 |
So I had the pleasure of driving my car for a few day before going out of town again for work. It's definitely a different engine than the L99 that I had in it before lol. Very quick on the gas pedal. It did have a bad surge with anything under about 2500 rpm. Had it taken to a turner yesterday. Left the dyno with 422 rwhp and the surging has calmed down a lot. Thus far I am happy with the turn out.
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 CGM 2SS/RS LS3 Swapped A6 Join Date: Sep 2016
Considering your mods probably had you around ± 360HP (assuming you don't have a CAI installed based on your original post), that's a really nice gain of 60+rwhp from a rather mild cam.
Just to be clear, you swapped the L99 cam for the hotcam or did you engine swap the L99 for the LS376/480? Either way, nice increase over stock!
#12 | |
#13 |
Congrats. I had the GM Hot Cam years ago in an LS1 Trans Am that I had (Same specs). It gives off a mean chop which sounded great, but did surge a lot until tuned. I remember picking up around 45ish to the wheels with that and a tune.
I'd probably invest in a CAI. It will only help at this point. If you are close to going with a Pro Charger, then forget it, but if that will still be a ways out, maybe look for a used one in the classifieds if you don't want to buy new. I run the OEM Z28 CAI (Which was designed by K&N, and uses their filter), and I couldn't be happier.
LSX Block, MAST 305 Black Labels, Exceldyne Valves, Diamond Pistons, Callies Crank & Rods, Cam Motion Cam, Johnson 2116LSR Lifters, Comp XDA Pushrods, Jesel Rockers, Mamo MSD, NW 102, Roto-Fab CAI, FAST 65# Injectors, ZL1 Fuel Pump, Kooks 2" Headers, Corsa Sport 3" Catback, Z28 Shifter, ZR1 Clutch, Katech LW Flywheel, 1LE 3.91 Diff, LPW Diff Cover, BMR - 1.4" Springs, LCA's, Trailing Arms, Toe Rods, Sway Bars, End Links, Diff Bushings, and Tunnel Brace, Z28/1LE Strut Tower Brace, Improved Racing Oil Cooler 2023 Camaro ZL1 / 1LE Stock |
#14 | |
| Tags |
| 3"exhaust, 376/480, hotcam, kooks, longtube |
