04-30-2019, 10:35 AM | #1 |
Drives: 2013 2ss Join Date: May 2011
Vary confused about master cylinder
Okay guys. I'm doing a auto to manual swap and I'm already basically finished but I went ahead and started bleeding my brakes and I got a aftermarket single brake fuild Reservoir for the for the clutch... the master in the tr6060 was good when we took it out of the other car. Now when I try to prime it it's leaking. Do these things just go out just like that with no warning...
2013 auto ss..full bmr suspension..3800 stall...s475 turbocharger on 16 psi with 150 nitrous outlet plate...,BTR stage 3 turbo cam.....100% Methanol injection....LY6 6.0 iorn block ...
04-30-2019, 11:00 AM | #2 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
Leaking from where? Did you tear an o-ring accidentally? Where was the part(s) sourced from? The unit on the trans is actually a slave...how are you bleeding the system?
good luck Peace
04-30-2019, 01:32 PM | #3 |
Me and a buddy are swapping. Because he wants automatic and I want manual. I went to bleed the system from the bleeder port on the save cylinder... I barely opened it to start putting fluid through it. Once I saw all the air bubbles go away I close the system. Then I tried pumping to get the clutch hard. And fluid was just gushing out from the Slave cylinder.. anyway the slave cylinder wasn't leaking in his car. And we didn't take it off or anything. I already ordered another slave so I guess I just have to wait it just pissed me off because I want to finish everything today
05-01-2019, 12:58 PM | #4 | |
Drives: 2012 camaro 45th 2ss/rs Centri SC Join Date: Nov 2016
don't use the bleeder to bleed lol. It doesn't really work.
This is the best and quickest way to get it done. I tried to use the bleeder screw and it was a disaster, though it sealed back up when I tighted it. I made this quick video
Jeremy
-2012 Camaro SS 45th M6-Kraftwerks Supercharger -2003 Avalanche z71-6" on 35's. DD 290k miles -66 mustang fuel injected resto-mod |
