Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Members Classifieds - Parts for sale or wanted > Transmission / Driveline
Old 04-30-2019, 12:31 PM   #1
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
Tick adjustable 5th gen Camaro Master cylinder NEW
It doesnt fit my application(Spec Mini Twin) so cant use it. It will fit 99.9% other application.
Installed and bled but never used.
My loss your gain.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE
Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me.
WHAMMO is offline   Reply With Quote
Old 07-28-2019, 03:19 PM   #2
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
Price drop 375$ shipped!
13' 1LE
Old 08-23-2019, 08:30 PM   #3
Jayjellyfish212
Jayjellyfish212's Avatar
Drives: 2014 1LE
Dang ...How come it didn’t fit your application? I was just looking at these and wasn’t aware of any application figment issues. I just put in a McLeod RXT twin disk. I upgraded the slave cylinder to with the Tick billet sleeve support & speed bleeder. I wonder if this would be an issue on my application now.. hmm
Do you have any pictures of the adjustable master clutch cylinder you got?? If I call
Tick and see if it would work on mine with my set up I would be interested in taking it off your hands but I wanna be certain it will work on my new set up.
Car mods: never enough!
Jayjellyfish212 is offline   Reply With Quote
Old 09-13-2019, 10:31 AM   #4
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
Like I said, there is no fitment issue. I am probably the only guy in America in a street car running a Mini Twin. My clutch is really tiny and it's not even supposed to work with our transmission; even Spec was wrong on the slave cyl size. I had a 2.5" spacer machined for it to work.
So It will fit 99.99% with all the other clutch stock or not stock.
13' 1LE
Old 09-16-2019, 04:13 AM   #5
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Does this go inside the car?
Orange Krush II
Old 04-21-2020, 10:27 AM   #6
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
Bump...350$ shipped
13' 1LE
Old 05-10-2020, 01:54 PM   #7
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
In the car!! behind the pedals and in the firewall.
13' 1LE
Old 05-19-2020, 08:50 PM   #8
SabsBee
Transforming
SabsBee's Avatar
Drives: Transformer Edition Camaro
still got this?
Rick P
Dual Masters in Special and General Ed
Camaros because they have the personality you design.
SabsBee is offline   Reply With Quote
