Old 05-01-2019, 12:30 AM   #1
itsanlfx
Drives: 2012 Chevrolet Camaro LT
Unhappy this sound is driving me nuts, please help
hello everyone,
this high pitched, light, metallic scratch-like ringing sound has been going on for years.
the dealers and garages i have taken to all advise me not to blow money off since they cannot guarantee results
this sound is driving me crazy and really is annoying
Case scenario:
Usually the Reverse gear will be the trigger and this never happens when under even the slightest load.
the sound only got WORSE and now happens on Drive more frequently than before.
Neutral gear still kills the sound.
Park, and it can happen sometimes.
Only happens at RESTING IDLE, never under load or when in motion? that last condition puzzles me.
recently, i have changed my exhaust clamps all around the car, i have the borla s-type aftermarket, and thats when it got worse. So i think that this must have finally brought me to the point where i can share this
Please help , o' fellow GM lovers
www.youtube.com/watch?v=rmBQYSvs-Lg
A Video of the Sound ^^
itsanlfx is offline   Reply With Quote
Old 05-01-2019, 11:25 AM   #2
STALKER
STALKER's Avatar
Drives: 2023 Camaro ZL1 1LE
Heat Shield maybe?
2014 Camaro SS Spring Edition LSX440ci
LSX Block, MAST 305 Black Labels, Exceldyne Valves, Diamond Pistons, Callies Crank & Rods, Cam Motion Cam, Johnson 2116LSR Lifters, Comp XDA Pushrods, Jesel Rockers, Mamo MSD, NW 102, Roto-Fab CAI, FAST 65# Injectors, ZL1 Fuel Pump, Kooks 2" Headers, Corsa Sport 3" Catback, Z28 Shifter, ZR1 Clutch, Katech LW Flywheel, 1LE 3.91 Diff, LPW Diff Cover, BMR - 1.4" Springs, LCA's, Trailing Arms, Toe Rods, Sway Bars, End Links, Diff Bushings, and Tunnel Brace, Z28/1LE Strut Tower Brace, Improved Racing Oil Cooler
2023 Camaro ZL1 / 1LE
Stock
STALKER is offline   Reply With Quote
Old 05-01-2019, 11:30 AM   #3
gringo
gringo's Avatar
Drives: Camaro V6
I don't hear anything abnormal in the video. Seems like normal LFX idling sounds to me.
gringo is offline   Reply With Quote
Old 05-01-2019, 11:51 AM   #4
wasthatacop?
wasthatacop?'s Avatar
Drives: 2010 2SS
This situation must be frustrating for you. How many miles on the odometer?
I'm no expert but it sounds like a belt or a bearing. Also, check and make sure that your power steering fluid is topped off. But power steering is usually a louder, higher pitched noise.
The part that's making it tough to figure out is that the Borla made it louder. Maybe it's an internal engine bearing?
2010 2SS living in Los Angeles
replaced engine @ 93,000 miles w/ crate engine, camshaft by Comp Cams installed by me, replaced valve train parts,
1.4" BMR lowering springs
ZL1 factory rims
misc: drilled and slotted rotors, fresh air brake cooling system, new speakers, installed reverse camera, muffler delete
wasthatacop? is offline   Reply With Quote
Old 05-01-2019, 11:57 AM   #5
wasthatacop?
Drives: 2010 2SS
I like what STALKER suggested. Perhaps a heat shield is slightly vibrating and rubbing on the engine, frame, etc. Those heat shields are allover the engine bay and can make replacing a starter a b***h.
ZL1 factory rims
Old 05-01-2019, 08:08 PM   #6
itsanlfx
I will try to inspect the heat shield, thanks for the suggestion
I have 79k km on there
The Borla exhaust was on the car since 35k
The sound was always there, but got worse gradually.
However with my recent meddling with the exhaust, I managed to increase it's frequency and volume
Sigh
Old 05-01-2019, 08:11 PM   #7
itsanlfx
Turn up the volume, you will notice a light metallic sound, it's not so light IRL , these mics do no justice and I don't have the equipment
Pretty annoying presence really haha
Old 05-01-2019, 10:52 PM   #8
gringo
gringo's Avatar
Drives: Camaro V6
Mine sounds the same. It's how these LFX's sound at idle.
Makes me laugh at the V8 owners chiming in this thread. They sound way different than the V6 at idle.
Old 05-01-2019, 10:55 PM   #9
itsanlfx
Gringo,
Do you have the same sound? Does it go away at idle?
Old 05-02-2019, 10:05 AM   #10
LuSINda
LuSINda's Avatar
Drives: 2010 2SS/RS
Please help , o' fellow GM lovers :D
[URL="www.youtube.com/watch?v=rmBQYSvs-Lg"
www.youtube.com/watch?v=rmBQYSvs-Lg[/URL]
Double check your exhaust pipes and clamps. Make sure none are vibrating on the frame.
Lusinda
2010 2SS/RS
LuSINda is offline   Reply With Quote
Old 05-02-2019, 11:10 AM   #11
Benman
Benman's Avatar
Drives: 13 IOM 2ss RS manual
Thank goodness for that, lol.
Benman is offline   Reply With Quote
Old 05-02-2019, 11:43 AM   #12
LuSINda
LuSINda's Avatar
Drives: 2010 2SS/RS
Originally Posted by STALKER View Post
Heat Shield maybe?
Can't hurt to have a look.
Lusinda
2010 2SS/RS
Old 05-02-2019, 01:00 PM   #13
qcman
qcman's Avatar
Drives: 2013 Camaro 2SS RDP Tuned L99
Oh you didn't just....
qcman is offline   Reply With Quote
Old 05-02-2019, 10:13 PM   #14
Joecruiser
Joecruiser's Avatar
Drives: 2014 2-SSRS Slushbox
Seems every thread becomes 6 vs 8☺
Hope you find a fix OP.
Joecruiser is offline   Reply With Quote
borla, camaro, lfx, problem, rattle
