Old 05-09-2019, 09:17 AM   #1
Moto-Mojo
Fast Cars and Old Guitars
Moto-Mojo's Avatar
Drives: 2015 2SS RS (L99, baby!)
Too Much Horsepower For What It Is? Stock L99 @ 499HP
Sound familiar? LOL. But seriously, check this simple formula from 'Chevy Hardcore' for estimating flywheel horsepower. Now math is not my strong suit but I double checked it:
Simply stated, it's a torque per cubic inch factor of 1.25 x cubic inches. That result x a 10% loss factor. That result x peak RPM. That result / by factor 5,252.
Thus:
1.25* x 376 CI = 470 LB FT
470 x .90 loss = 423 LB FT
423 x 6200 RPM = 2,622,600
2,622,600 / 5,252 = 499.3 Peak HP
*based on 10:1 compression ratio. If you use 1.3 for the higher LS3 engine, it comes out to 519 peak HP.
So...is this article full of it? Did GM UNDER estimate or did I fail yet another math test.
https://www.chevyhardcore.com/news/j...use-right-now/
Moto-Mojo is offline   Reply With Quote
Old 05-09-2019, 09:33 AM   #2
gtstorey
So our engines don't make the 1.25 Lb ft per cubic inch. More like 1 - 1.1 in stock form. Aftermarket heads, cam and LT headers are more in the 1.25-1.3 range.
Old 05-09-2019, 09:37 AM   #3
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
Those numbers are right, back in 09 one of the tv hot rod shows ran a LS3 on an engine dyno and they got just over the 500 mark. The numbers Chevy gives us a certified net and not gross.
Old 05-09-2019, 09:54 AM   #4
qcman
qcman's Avatar
Drives: 2013 Camaro 2SS RDP Tuned L99
If you look at the L99 which Dyno's about 330 RWHP and assuming 18-20% drivetrain loss that would put the L99 pretty close to the 400 HP Chevy claims. On the 2013 and later cars with the Electric Power Steering ( I don't think 2012's had it yet?) there should be a bit more crank horsepower as the motor is no longer turning the old hydraulic power steering pump.
I love the title of the thread BTW LOL.
qcman is offline   Reply With Quote
Old 05-09-2019, 10:04 AM   #5
SlingShot
SlingShot's Avatar
It would be more net, then gross would stay the same. The net is with all belts and accessories.
Old 05-09-2019, 10:06 AM   #6
qcman
qcman's Avatar
Right that was what I was trying to say. You said it better
Old 05-09-2019, 10:10 AM   #7
Moto-Mojo
Moto-Mojo's Avatar
So is it really more than the claimed 400HP? Not completely understanding net v gross...
Old 05-09-2019, 10:14 AM   #8
qcman
qcman's Avatar
I would say no in the sense the 400 HP includes the belts etc. (net) which is what they report but the HP on just the block (gross)would be higher than 400 though I don't know by how much.
I believe back in the 60's when they claimed HP on motors they were reporting gross which was a little misleading. I'm not sure thats what they did though.
Old 05-09-2019, 10:24 AM   #9
PepeLePew
PepeLePew's Avatar
Drives: 2010 2SS Coupe; 2011 2LT Vert
Cool article Moto-Mojo. I think the math works. I wonder what this line in the article means with regards to the heads and cam:
"Brule’ likes to use 1.25 lb-ft per cubic inch for a 10:1 compression street engine with good cylinder heads and a decent camshaft."
We know that the L99 and LS3 heads are awesome to begin with, but I wonder if they consider the stock cam as a decent camshaft. It seems like based on the results of your calculations, they probably do.
What I'd love to see if anyone has done it, is a test where they run the engine without accessories on the dyno and compare it to with accessories and then put the engine in the car and run it on the chassis dyno. Do this for the L99 and the LS3. That would give us an excellent idea of how much loss is associated with accessories and drive trains (auto and manual). That would take a lot of the guess work out of estimating flywheel/flexplate numbers. Just fun to know stuff!!!
Oh and funny topic title too. I wonder if we'll get any interest on this thread from our favorite troll.
2010 2SS/RS LS3 - K&N, GM Performance Axle Back, Hurst Shifter, TSP 1 7/8ths long tubes no cats, TSP Stage 2 "Bald Eagle" cam, GM 3.91, 466whp/429tq
PepeLePew is offline   Reply With Quote
Old 05-09-2019, 10:28 AM   #10
Moto-Mojo
Moto-Mojo's Avatar
Ok, so that’s still 488HP. (1.1) Seems I have new bragging rights.
Old 05-09-2019, 10:34 AM   #11
Moto-Mojo
Moto-Mojo's Avatar
Yeah, I borrowed his tag line as bait!
Old 05-09-2019, 10:40 AM   #12
qcman
qcman's Avatar
Be ready to set the hook!
Old 05-09-2019, 10:58 AM   #13
SlingShot
SlingShot's Avatar
Back in 09 the V6 was not certified and Chevy just did a guestiment on the power. The said it was 304hp, sometime in 10 they did a certification at 323hp.
Old 05-09-2019, 11:01 AM   #14
qcman
qcman's Avatar
I think they went from 304 to 312 for the LLT and then to 323 when it changed to being the LFX in 2012 iirc.
