Old 05-09-2019, 10:38 PM   #1
Kinglinton22
Drives: 2016 Camaro 2SS
New Rims
I just installed new 20 inch rims on my 2014 camaro, they are 20x10 all around and the are setting off five lights on the dash. What's should I do, would a 20x8.5 rim fix that? Help
Kinglinton22 is offline   Reply With Quote
Old 05-09-2019, 10:45 PM   #2
Mr2Hard2See
Instagram: Mr2Hard2See
Mr2Hard2See's Avatar
Drives: 2011 2SS/ RS
What size are your tires all 4?
YOUTUBE CHANNEL: Mr2Hard2See
LSA blower BTR stg 2 cam 227/242
BTR dual springs pushrods lifters retainers etc
Che bronze trunnion Ls3 timing/valley cover
Dod/vvt delete Dsx e85 Dsx aux fuel pump Id1050x injectors ZL1 fuel pump, Griptech 2.55 pulley, Solo performance Mach ll 2.5 catback exhaust 1 7/8th Lt headers
Mr2Hard2See is offline   Reply With Quote
Old 05-09-2019, 11:03 PM   #3
Kinglinton22
Fronts 245 45 20
Rear 275 40 20
Old 05-09-2019, 11:41 PM   #4
Mr2Hard2See
245/45/20=28.7 height
275/40/20=28.7 height
Did you install the tire sensors and get an alignment? I’m quite sure someone here can help you figure this out. I thought if your tire goes beyond .3 height difference front to rear is when you run into issues but the tire calculator data was the same.
Old 05-10-2019, 02:10 AM   #5
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2019 XTS, 2013 SS
What lights are being set off? Your information is vague.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
TheFlyingBananaSS is offline   Reply With Quote
Old 05-10-2019, 02:37 AM   #6
weSS1LEy
weSS1LEy
weSS1LEy's Avatar
Drives: 2015 camaro 2ss/rs/1le
So lots of guys are running 295 front and 315 rear. With a .6 height difference. Does that cause a problem? I never came across a thread about it
Rotofab, arh no cats, atak, elite cc, 94 octane tune, Mobil 1, phastek scoop, custom cam 230/243 .621 .604 114+4, related cam kit stuff. 470/435 rwhp/rwtq
weSS1LEy is offline   Reply With Quote
Old 05-10-2019, 08:33 AM   #7
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #832
I agree. What are the "five lights" that are being set off? You should be ok with that wheel size unless a sensor or something got damaged during the wheel installation.
Check out my build thread
Old 05-10-2019, 09:39 AM   #8
DRKS1D3
DRKS1D3's Avatar
Drives: '17 Corvette Grand Sport M7
First, as others have asked, what are the "five lights"?
Secondly, when swapping wheels and tires, do it right and buy the correct sizes. If you don't have the money to do both, there are obviously more important things in life that need to be tended to. The stock RS wheels are 8" front and 9" rear. It appears to me that you took your stock tires and put them on the wider wheels. The 275's are ok, but stretching a 245 onto a 10" wheel is not smart! With that being said, I still don't see what would cause the car to panic. Get back to us with more info. Good luck!
MY RIDE: 2017 CORVETTE GRAND SPORT--TRIPLE BLACK, 7 SPEED MANUAL, VARARAM TCR-7 INTAKE, BORLA CATLESS X-PIPE, CARBON FIBER STAGE 2 AERO, MGW SHORT-THROW SHIFTER
**SOLD**2011 TRIPLE BLACK SS CONVERTIBLE--6 SPEED MANUAL, MANY MODS, 455 RWHP/435 RWTQ
DAD'S RIDE: 2012 ZL1 #1866--BLACK, 6 SPEED MANUAL, EXPOSED CF HOOD, POLISHED WHEELS, SUNROOF, ROTO-FAB INTAKE
"Silly Americans, taking from the rich and giving to the poor only works in fairy tales. Success is earned here!".
DRKS1D3 is offline   Reply With Quote
Old 05-10-2019, 09:50 AM   #9
ZEN357
ZEN357's Avatar
Drives: 1991 Z/28 Convertible
Sounds like the TPMS sensors weren't installed.
ZEN357 is offline   Reply With Quote
Old 05-10-2019, 09:53 AM   #10
GearheadSS
GearheadSS's Avatar
Drives: 23 LT1/86 IROC-Z
Originally Posted by Kinglinton22 View Post
Fronts 245 45 20
Rear 275 40 20
Those front tires are WAY too narrow for a 10" wide wheel.
GearheadSS is offline   Reply With Quote
Old 05-10-2019, 10:01 AM   #11
Junior
Junior's Avatar
Drives: 2014 2SS/RS A6 AGM
Send a message via Skype™ to Junior
I hate seeing stretched tires almost as much as I hate the usually associated extreme negative camber
Junior is offline   Reply With Quote
Old 05-10-2019, 10:09 AM   #12
Kinglinton22
The light are ABS, Brake, Stabilitrak, traction control
Old 05-10-2019, 10:14 AM   #13
Kinglinton22
Would 275 upfront fix the problem
Old 05-10-2019, 11:03 AM   #14
DRKS1D3
DRKS1D3's Avatar
A 275 would certainly be better than a 245, but it is still NOT ideal. I ran 20x9 wheels on all four corners of my SS with 285/35/20 GY Eagle Supercar G2's.
