![]() Drives: 2010 2SS RS Join Date: Mar 2011
Understanding GM part listings
Hi guys, usually I'm able to find the information I need on here pretty readily, and I don't think I've ever posted a question before in 9 years of being on here(!), but recently I've been having a tough time finding information on the flex couplings used on the driveshaft for my 2010 2SS. Initially I thought the correct part looked to be 9228328, but when it came time to actually order it for some reason the online tools kept pointing me to 9228337. However, after having ordered and received two of them, they're too small. It makes sense after looking at the description online again, as it describes it as "COUPLING KIT,PROP SHF(105X30)" and the other which I think is probably correct lists "COUPLING KIT,PROP SHF(110X30)". I'm guessing the 110 is referencing a diameter measurement, though I haven't taken the caliper to it to see.
Now, when I go to the dealership or go to place an order at another GM site, everyone points me to 92249108. But, from the best I can tell, the difference here is that this includes the hardware to attach the coupler to the driveshaft, which I don't need because I have quite a few of them on-hand already. The only other minor difference I see in the listings that may matter are that the first part, 92228328, says "For: ES 6-SPD MAN TRANS(M10) (2010-2011) (2010 - 2011)," whereas the second says, "COUPLING KIT, Propeller Shaft Pinion. For: EE,EF,ES 6-SPD M/TRANS(M10) (2010 - 2011)". Does anyone know what the "EE, EF, and ES" means in these listings? That's the only thing that makes me question my observation that the only difference in the part numbers is that second, more expensive kit includes the fasteners I don't need. Oh - and does anyone know what they mean with 'MYB', and 'MYC' in some of the part listings? That seems to be the only difference between the parts for the entire driveshaft assembly. Thanks! Last edited by HoTWiReZ; 05-13-2019 at 01:19 PM. Reason: Added question about 'MYB' |
For a 2010 manual transmission SS, you would need GM part# 92249108 flange. Depending on your VIN you may also need a yoke part# 19257695 and flange part# 92249271 as GM changed the design through the 2010 build year.
MYC= 6l80 Auto MYB= 6l50 Auto ( 6 cyl cars) M10= 6 Speed tremec (SS) MV5= AISN Trans (6 cyl manual) EE=LS EF=LT ES=SS Hope this helps ya |
OH and the 8337 you are getting is for 6 cyl auto car the MYB 6L50
also the 92228328 is for an auto SS with the 6l80,and the only way to get the couplers is the whole kit. Last edited by GMParts; 05-17-2019 at 12:36 PM. Reason: added info |
Thanks a bunch, that is helpful. I did figure out the couplers I ordered were too small for that driveshaft.
I eventually spoke to a very helpful parts guy to understand I'm in the boat you described where I'll have to replace the yoke and flange that each end connects with because GM changed the couplers to be narrower. I guess that would help reduce the frequency folks are bending the bolts there, so it's a smart change.I wound up reusing my couplers and installing new bolts and nuts. I think with the price to replace the parts it makes sense to just plan for an aftermarket driveshaft. |
'69 Owned Since '79
Drives: '69 Z/28 LeMans Blue w/White Join Date: Oct 2008
Just my experience - If you carefully replace the bolts and nuts with the current service replacements you might be fine. I have done a few early on with my 2010 SS and not had any repeat failures. Now at 80K miles. I am using the factory torque settings specific to where the fasteners are installed (varies depending on where the bolts are on the driveshaft assembly) using a beam type torque wrench and all new fasteners.
520 RWHP supercharged with 6 spd manual. |
#6 |
Geoff
Drives: 2022 SS 1LE Join Date: May 2013
Older thread warning
I'm a bit unsure about what coupler I need
I have a 13 1LE (SS w/ manual trans) GM says they only sell the couplers with the complete driveshaft. HOWEVER, you can order separately if you know the correct part number. My parts guy can't see what vehicle or driveshaft the couplers go on. Before I saw this thread I ordered 92228337, and the coupler is too small. The info I've found so far is that 92228328 is for LS, LT and SS cars, but only the automatic transmissions. I found this "for sale" thread https://www.camaro5.com/forums/showt...eshaft+coupler It is for a coupler from an L99 car the picture has GAC02-004 on the coupler, mine has the same number (see below) Has anyone put 92228328 in a manual transmission SS?
#7 |
Geoff
The 92228328 coupling kit has the GAC02-004 Made In Germany Coupler, Bolts, Washers & Nuts that are correct for the 5th Gen manual SS and Z28 cars. Not the ZL1 cars.
First pic is damaged (112,000k miles) coupler and second is 92228328 kit with old coupler
#8 |
Does any body have any idea where to get the kit 92249108 or the coupling 92228328? I need one for my 2010 SS Manual transmission. Everywhere I look now says it is discontinued. What is the current replacement part design? Hopefully I'm not in a position where they tell me to buy a whole new driveshaft...
#9 |
HomezSS
Drives: 2014 SS/RS Camaro, 2011 Silverado Join Date: Jul 2014
All - found this thread, i too am in need of the flex coupler for my 2014 SS Auto. Part # 92228328 is the correct part but is discontinued by both GM and AC Delco! So far i have not been able to find any substitute - this car is only 8 years old - seems odd what appears to be a "wear part" is suddenly un-obtainuim?!?!?
HOMEZSS
2014 SS/RS, FR Style 41's, 20x10x4, Borla CatBack with Touring Mufflers w/Magnaflow Glasspacks, Cold Air Inductions Intake, Diablo 91 Octane Tune, Firm Shift, AFM off, BMR cradle inserts, trailing arms and toe links, 1LE/ZL1 Rear Sway Bar, Jannetty Custom Tune for mods noted above (noticable change to how the car drives!!), JL Audio XD700/5 amp and 10 inch Sub, Focal PS 165K's, special wiring kit and amp board, and lots of dynamat (Amazon version) - Sounds GREAT, Runs Even Better! |
#10 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2014 2SS/RS 6SP Ashen Grey Join Date: Aug 2021
It is Crazty that a wear item like this is discontinued, It appears most people at some point will have to switch to a 1 Piece shaft. A 1 piece shaft is the way to go in my opinion as I do know first hand the difference an aluminum shaft makes and in these cars they must make a bigger difference.
Dodge uses this set up on the chargers ( Not sure about challenger ) and we replace them all of the time.
GM 3.91/TrueTrac OEM ZL1 Rims, 6 Piston Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, GC Aluminum DS,Stainless Works Ceramic LTH/HiFlo Cats, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace, Moroso Catch Can,SCT X4 Dynosteve,Remote Clutch reservoir,Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount. |
