Old 05-13-2019, 10:43 PM   #1
fstomp
Drives: Chevrolet Camaro
L99 6l80e manual swap
Hey looking to build my camaro for the track it’s a 2012 camaro 1ss with the 6L80E... I’ve been looking to swap out the trans to a Tr6060 but have no clue how to go about it as in what will be needed (like wiring and tuning) and if it’ll be an easy bolt on swap minus tuning. If anyone has done it any advice and what will I need to do to get a tr6060 into my camaro.
fstomp is offline   Reply With Quote
Old 05-14-2019, 12:12 AM   #2
Terryfied
Terryfied's Avatar
Drives: 2010 2SS L99
Sell it and buy a manual or trade it for one.
Terryfied is offline   Reply With Quote
Old 05-14-2019, 01:46 AM   #3
Athletics101
Athletics101's Avatar
Drives: 5th Gen L99
+1
LSA conversion 2.5 upper 10% lower, L99 converted to LS3. TSP 229/244 cam, TSP LS3 ported and milled heads milled .015,Kooks LT’s no cats, Roto Fab, Borla arak cat back. 3200 stall,Forgestar F14 18’s and drag radials, pedders coil overs, BMR trailing arms & adjustable toe rods, mildly stripped Interior 685/613 on E 610/571 on 91
Athletics101 is offline   Reply With Quote
Old 05-14-2019, 02:41 AM   #4
John_C
LSx FTW!!!
Drives: 2010 Camaro 2SS RS
I wouldn't think it's too difficult to swap an auto to manual.
I did that myself in a Mustang GT I had before this SS.
I can say this, it won't be cheap though.
Just swapping up to a 6L90 in my SS was a chunk!
John_C is offline   Reply With Quote
Old 05-14-2019, 09:45 AM   #5
Moto-Mojo
Fast Cars and Old Guitars
Moto-Mojo's Avatar
Drives: 2015 2SS RS (L99, baby!)
When I have to admit this, I generally pay to have it done right. Just sayin...
Moto-Mojo is offline   Reply With Quote
Old 05-14-2019, 12:44 PM   #6
Roader
Drives: Camaro
Yep, I looked into this and was not as cheap as I expected once I started piecing all the parts together
Roader is offline   Reply With Quote
Old 05-14-2019, 12:54 PM   #7
PepeLePew
PepeLePew's Avatar
Drives: 2010 2SS Coupe; 2011 2LT Vert
Unless you are married to your car and have a ton of work and time invested in it and can't see yourself parting with it, you are way better off to do what the others said. Sell it and buy another car.
The cost alone to do a swap like this should be enough to stop you even if you did all the work yourself... even if you found a donor car. This is a partial list of the stuff you'll need:
1. TR6060
2. Flywheel
3. Clutch
4. Transmission Controller
5. pedal assembly (brake and clutch)
6. Hydraulics (master and slave cylinder and lines)
7. Console for shifter
8. Tuning
All of that on the cheapest end will be in the $5,000 - $6,000 range if you did it yourself. If you dont have a lift and the tools and the know how to do it though, you're looking at 2-3 days of labor minimum... my guess is $1600-$2400 labor only.
For reference, my buddy had a refurbished 6L80e swapped in his suburban by a local transmission shop that was a direct replacement for $3,000.
2010 2SS/RS LS3 - K&N, GM Performance Axle Back, Hurst Shifter, TSP 1 7/8ths long tubes no cats, TSP Stage 2 "Bald Eagle" cam, GM 3.91, 466whp/429tq
PepeLePew is offline   Reply With Quote
camaro, transmission help, transmission swap
