Old 05-15-2019, 08:36 PM   #1
rednecks70
Drives: 2013 AGM ZL1, '70 Chevelle 454
Finally got a ZL1!!
Well, after a lot of consideration I pulled the trigger on a 2013 Ashen Gray Metallic ZL1 with 28,000 miles and a 6 speed. I've owned other performance cars in past but none of them even come close to this car, I couldn't be happier with it. Had it shipped from 1,000 miles away and got to drive it today for the first time, I can't get the smile off my face!
I do have a few questions:
1) Can the hill assist be deactivated? It's annoying.
2) How can I tell if the pulleys are stock? It feels faster than a 2014 ZL1 I test drove that was totally stock. My car does have a cold air intake and oil separator, plus the exhaust sound louder. The dealership I paid to inspect it before I bought it claims the exhaust is stock but it's getting inspected in my state on Friday and I will ask them to double check.
3) Can I use plastic restorer on the front chin splitter? It feels like plastic and looks a little dull.
4) Can anyone suggest a good car cover? I only have a one car garage and have classic car insurance on my Chevelle that mandates it be in the garage. I may have to find someone to garage the ZL1 for me over the winter months.
Here is a pic, it was overcast so not that great of a pic. When the sun decides to come out I will get a better one.
Thanks!
rednecks70 is offline   Reply With Quote
Old 05-15-2019, 08:46 PM   #2
Ds98formula
Ds98formula's Avatar
Drives: 2015 M6 ZL1, 2012 silverado
Nice car. Congrats.
You can measure the pulley. Top pulley should be 2.95 and bottoms should be 7.8 not counting the guard.
2015 M6 ZL1 Bright Yellow: Cold Aid Inductions intake, 2.55 Griptec pulley,Kooks headers with high flow cats, Borla Atak cat back, ID1050's, Aux pump, Flex Fuel sensor 635whp 633wtq
Ds98formula is offline   Reply With Quote
Old 05-15-2019, 09:19 PM   #3
StreetRage320
Those who need me got me
StreetRage320's Avatar
Drives: 2022 ZL1 A10
Above pulley info is accurate a lot of people also pulled the f8 fuse to leave the flaps open making the exhaust louder. It may be a factory exhaust and simply just missing that fuse?
StreetRage320 is offline   Reply With Quote
Old 05-15-2019, 09:27 PM   #4
StreetRage320
Oh and by the way 2013 r faster than 2014 it's not some sort of illusion lol
Old 05-15-2019, 09:34 PM   #5
rednecks70
It must be the cool looking tail lights that make the 2013 faster
I limited my search to 2012 and 2013 because of the tail lights. Plus their also a little less expensive.
Thanks to both of you on the pulleys. I will get the tape measure out in the near future.
Where can I find the f8 fuse?
Old 05-15-2019, 10:01 PM   #6
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
Congrats!! You're going to love it. Best car I've ever owned.
The fuse is in the trunk, on the right hand side. Here's a post that has a photo of where it is located:
https://www.camaro5.com/forums/showthread.php?t=226858
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp // CSP LT's & Ultra Cats // JMS // Elite Ultra CC // BMR MM // BC Forged KL13
Mods being installed-
oil pump, cam, ported heads, dual in-tank, Goliath and XDI, etc., etc.
RobZL1 is offline   Reply With Quote
Old 05-16-2019, 08:13 AM   #7
GONMAD510
Drives: 2013 ZL1 M6
The main reason I bought my 2013 was for the tail lights.
Fast 850cc Injectors, ATI Balancer, 8.66 Lower Pulley, 2.55 Upper Pulley, Lingenfelter CAI, Kooks LT with cat delete pipes, Noweeds Exhaust Cutouts (extremely loud under full throttle), BTR Stage 3 Cam, BTR Platinum 660 Valve Spring Kit, TR7ix Iridium Spark Plugs, Lingenfelter Solid Isolator, 160 Degree Thermostat, Larger SC Coolant Reservoir with Hose Relocation Kit, BMR 1.25" Lowering Springs, MGW Short Throw Shifter, Racing Brake 2 piece rotors front and rear, Starkweather Performance Custom Dyno Tune on 91 Octane.
691.38 RWHP
630.35 RWTQ
GONMAD510 is offline   Reply With Quote
Old 05-16-2019, 12:01 PM   #8
LevonH
Chevy Enthusiast.
Drives: 2015 Camaro ZL1 Summit White
Hi John. Looks like there are several of us that have gone to the ZL1. Glad you kept your Chevelle. I sold mine.
See you over on Chevelles.com as well
Here's my 2015. Took the black ZL1 wheels/tires off for now as I am planning a few long mile trips. Put the SS wheels on with new tires for the trip.
Levon H. Bone Stock
LevonH is offline   Reply With Quote
Old 05-16-2019, 01:06 PM   #9
lbls1
lbls1's Avatar
Drives: 2002 Camaro SS SOM; 2015 Malibu LTZ
You will be very happy with it. Congrats.
'02 CAMARO SS SOM; 5.7L LS1/FLS6B
'08 TBSS AWD Black Granite Metallic
'15 Malibu LTZ 2LZ Turbo
'14 CAMARO ZL1 Blue Ray Metallic
'25 Silverado 1500 High Country 6.2L
lbls1 is offline   Reply With Quote
Old 05-16-2019, 01:29 PM   #10
DrkPhx
DrkPhx's Avatar
Welcome.
- There is no switch to turn it on or off. It would require some modification to remove. There was a thread here a few years back that detailed the process.
- You could measure them as noted above. Stock boost psi is 9 psi so it may be a little more with a CAI.However depending on the exhaust it may be different.
- I would bring it to a 3rd party inspector to make sure it's emissions compliant if your states checks for it. I would also check to make sure the stock NPP mufflers are intact.
- Wipe it down with Simply Green to see if that helps. I use Pig Spit spray which keeps the factory looking finish without any glossiness.
- Indoor or Outdoor? GM used to make two versions for the 5th gen ZL1; black for indoor and silver for Outdoor. Otherwise there are some quality aftermarket ones out there.
Old 05-16-2019, 02:06 PM   #11
rednecks70
Thanks, I will look for it and see if they pulled the fuse.
Old 05-16-2019, 02:08 PM   #12
rednecks70
Levon, I remember seeing your name over on Chevelles.com. Very nice ZL1! I really want to keep my Chevelle, I've put a lot of time and money into it and have yet to reap the full benefits, still trying to iron out a few bugs. Wish I had a 2 car garage, my ZL1 is in very good shape and want to keep it that way.
Old 05-16-2019, 02:12 PM   #13
rednecks70
Originally Posted by DrkPhx View Post
Welcome.
Thanks for the info. I need an outdoor cover for now. Hopefully I can find a friend or relative that will let me use their garage over the winter. This car is not going to see one snow flake if I can help it!
Old 05-17-2019, 11:30 AM   #14
VRZL113
VRZL113's Avatar
Drives: 2013 VR ZL1, M6
I believe the hill assist can be deactivated by switching the yaw sensor to the one found in the automatics... there's a few threads on it. I hated the hill assist at first, but on super steep inclines with ignorant motorists riding up on you, it comes in handy.
The worse feature is the skip shift, but that can also be taken care of. See Phastek for their skip shift eliminator.
#3257 | 485whp 526wtq | K&N 63-3079 | Gates K080660HD (Green Belt) | ACDelco UPF48R | ZL1 Addons Wicker Bill | Mild2Wild
VRZL113 is offline   Reply With Quote
