Old 05-19-2019, 10:20 AM   #1
frey.199
Drives: 2010 Camaro 2SS
Wheel Lugs grrrrrrrr
So tried to get my wheels off using a 24mm socket, then a 22mm, neither worked, I so figured 23mm (of course I didn’t have one). Went to auto zone and got one and came back and still doesn’t fit all that great, somewhat wiggles. I tried to crank the lug off anyway and it just kept skipping. I didn’t keep trying long because I didn’t want to round out the lugs.
Any ideas or am I doing something completely wrong? I’ve never had these tires off and this is getting ridiculous.
frey.199 is offline   Reply With Quote
Old 05-19-2019, 10:26 AM   #2
Vegas Bound
Drives: 2013 Sparkly Red One
22.5mm.
Vegas Bound is offline   Reply With Quote
Old 05-19-2019, 11:29 AM   #3
frey.199
Originally Posted by Vegas Bound View Post
22.5mm.
Seriously? Why would Chevy do that....thank you!
Old 05-19-2019, 11:51 AM   #4
LevonH
Chevy Enthusiast.
Drives: 2015 Camaro ZL1 Summit White
22mm works on mine.
Levon H. Bone Stock
LevonH is offline   Reply With Quote
Old 05-19-2019, 02:36 PM   #5
frey.199
So I got 7/8” and even tried 13/16”. The 7/8” is slipping just the same as 23cm. I’m pretty these lugs have caps on them. Their seems to be absolutely no grip to them. Any ideas?
Old 05-19-2019, 02:37 PM   #6
Vegas Bound
Ask the Canadians.
Old 05-19-2019, 03:15 PM   #7
Silveradoss573
Banned
Drives: Camaro 1LE
22mm is what I use. 7/8" fits as well. If the caps are spinning then you'll have to take a pair of pliers and pull them off. Then use a smaller socket to remove the lug nuts. You'll of course have to buy new lug nuts. Whatever you do don't buy the cheap junk that your local part stores carry.
Silveradoss573 is offline   Reply With Quote
Old 05-19-2019, 04:37 PM   #8
Nb1081
Drives: 10 2ss/rs
Pound a lil smaller socket on there you will get it off then have to hit the side of socket with it resting on ground and the lug will pop out of the socket its a pain in the ass but it works the lug starts to rust between chrome skin and changes size then crack i live in ny and deal with tons of salt so everything gets never seize o if the chrome cap pops off 3/4 usually works
[/SIGPIC]10 2ss ls3 sw long tubes,cai intake,phastek scoop,se3" exhaust,elite e2, bw stg2tb, tsp f35, motive 4.10 lpw cover, 15" conversion, 510whp tuned by john donovan
Nb1081 is offline   Reply With Quote
Old 05-20-2019, 11:12 AM   #9
frey.199
I finally got them off to realize I think the main issue was because they were stripped to hell. That's what I ended up doing Nb1081, just pound the socket on the lug. Going to buy new lugs today.
Old 05-20-2019, 02:58 PM   #10
mr_honez
Wifey Lover
mr_honez's Avatar
Drives: 2013 2LT to 2SS Manual Conversion
Replaced all my lugs with solid chrome ones after taking off my wheels the first time. Capped lugs suck
mr_honez is offline   Reply With Quote
Old 07-06-2019, 12:21 AM   #11
Sleeper_Six
Sleeper_Six's Avatar
Drives: 2011 Camaro 2SS
The first time I tried to change my brake pads, it was a nightmare specifically because of this. It turned a 20-30 minute project into a day long event.
I replaced the old rounded 22.5mm with some nice non-rounded-corner 23mm that I can zap right off in a flash now.
Sleeper_Six is offline   Reply With Quote
