Old 05-20-2019, 12:23 PM   #1
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
Help with short block selection...
So I spun a rod bearing.... tore motor apart everything else looks ok. I would like to reuse my stock ported heads and TSP stage 4 cam 235/239.
For the time and money I was looking at the 427's... jegs and summit has them for $5k... in stock. Any reason not to pull the trigger?
Or... build a 418 with my block, save a little money... but its going to take more time.
Buy a 418 from TSP... but these are more $ than the 427 and will take a couple weeks.
What should I do?
(No nitrous or FI)
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
Old 05-20-2019, 12:36 PM   #2
Bo White
Bo White's Avatar
418
Old 05-20-2019, 12:42 PM   #3
sixty9fordkiller
Donkey Dick Cam Camaro
sixty9fordkiller's Avatar
Drives: 2010 2SS/RS LS3 M6
if i was in your position, without hesitation id get this
https://www.summitracing.com/parts/c...058-3/overview
Bone Stock
sixty9fordkiller is offline   Reply With Quote
Old 05-20-2019, 12:43 PM   #4
sixty9fordkiller
......and use my existing LS3 block
Bone Stock
Old 05-20-2019, 12:46 PM   #5
sixty9fordkiller
One more thing, Clark....That LOD X1 manifold is gonna be in its sweetspot with the additional cubic inch
Bone Stock
Old 05-20-2019, 12:58 PM   #6
Clarkstar
Clarkstar's Avatar
It just seems like but the time I have my block cleaned, honed and assembled with the stroker rotating assembly.... wouldn't I be better off just buying the 427... and it comes with a warranty....???
Old 05-20-2019, 01:12 PM   #7
sixty9fordkiller
are you talking about this one?
https://sdparts.com/i-24080839-bluep...AaAs0mEALw_wcB
Bone Stock
Old 05-20-2019, 01:17 PM   #8
sixty9fordkiller
the only issue i would see is that its not a "real" LS7 427. GM got that cubic inch by going with a 4.125 bore
a 4.125 stroke like the one that im assuming you're looking at may not live as long as you'd expect it to. a 416-418 will live a lot longer.
the piston speed in a 427-429 LS3 will become an issue. That why i would stay with a 4.000 stroke
Bone Stock
Old 05-20-2019, 01:22 PM   #9
Clarkstar
Clarkstar's Avatar
https://www.jegs.com/i/Blueprint+Eng...0Q_CncPnHgZfjp
This one....
Old 05-20-2019, 01:27 PM   #10
Clarkstar
Clarkstar's Avatar
Originally Posted by sixty9fordkiller View Post
Yes... that one
Old 05-20-2019, 01:37 PM   #11
sixty9fordkiller
yeah its the same one. all those come from scroggin dickey if im not mistaken.
I would't go with that big of a stroke on a stock LS3 block. But thats just me
my thinking is: "why pay for another LS3 block and have that prepped when i already have the LS3 block and can just pay to have IT prepped"
i don't mind spending the money if i absolutely need to. But i already bought an LS3 block from GM when i bought the car so if its still good, i would just have that prepped and get a 416/418 kit and put it together myself.
Bone Stock
Old 05-20-2019, 01:45 PM   #12
Clarkstar
Clarkstar's Avatar
Your right... I'm just impatient... if I could find a 418 for $5k that ships tomorrow I'd do it.
Im still on the fence...
Old 05-20-2019, 02:05 PM   #13
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
https://www.shafiroff.com/chevy-ls-s...-block-ls3.php
You should be able to sell your old shortblock to make up for shipping and extra cost
2015 1LE, TSP 225/236 113+3, VMAX Throttle Body, CAI with race scoop, GPI Ported Intake, Land Speed Stage 2 Heads, 1-7/8 headers, NPP exhaust, 25% Fluidampr, LT1-S Monster Clutch, 485 RWHP & 444 TQ
zz430camaro is offline   Reply With Quote
Old 05-20-2019, 04:33 PM   #14
Clarkstar
Clarkstar's Avatar
I called, there 5-6 weeks out
