Old 05-25-2019, 08:40 PM   #1
rich2342
rich2342's Avatar
Drives: 2010 CGM Camaro SS
Ugh! 3 Quarts Low ~3500 miles.
Took my car into Chevy today for an oil change after only 3500 miles and asked them to check how much came out.
Well only 5qts!! Last oil change was not at dealer and they supposedly used 8 qts possibly semi sythetic according to reciept.
What damage might have been done, and is this type of consumption normal for the LS3??
I will have to check at frequent intervals for future loss.
Anyone have any inputs?
rich2342 is offline   Reply With Quote
Old 05-25-2019, 08:58 PM   #2
RankSS
Drives: 2010 Camaro SS
Too many variables. How much really went in? How much really came out? Watch the dipstick going forward. At the add mark it is down 1 quart.
2010 Camaro SS RS, Maggie with 3.4" pulley, 60# injectors, ADM dual fuel pumps, ADM Stage 2 Cam with Brian Tooley springs and pushrods, black CAI intake, Stainless Works long tube headers w/gutted cats, ZL1 Diff w/offset bushings, Pfadt lowering springs, Pfadt sway bars, Pfadt solid sub frame mounts, BMR trailing arms and toe rods, Hurst short throw shifter, Painted on Hugger Orange stripes, Forgestar F14 Piano Black wheels, Nitto NT05 rubber.
RankSS is offline   Reply With Quote
Old 05-25-2019, 09:56 PM   #3
rich2342
rich2342's Avatar
According to reciept, 8 qts semi synthetic 5w-30.
Reset mileage and was under 3500. Oil light popped on about 300 miles ago and added half qt becuase I cant read the stick at all. Didnt want to overfill and thus brought in for change and asked about the qty out.
Old 05-25-2019, 10:39 PM   #4
CamaroFred
CamaroFred's Avatar
Drives: Miss Con Ception
Have you checked it again since the change? I always check the next morning in case there is a leak. If you were 3 quarts low there wouldn't be anything on the stick, making it impossible to read.
Fortunately for us, the extra quarts are more for cooling than lubing so it's unlikely you would have any damage.
2011 1SS/RS LS3 CGM
CamaroFred is offline   Reply With Quote
Old 05-26-2019, 08:37 AM   #5
rich2342
rich2342's Avatar
Just had it changed yesterday. I have not checked it yet. I was going to to do the 500 mile check. I should check today.
Old 05-27-2019, 10:58 AM   #6
Eddiefuzz
Eddiefuzz's Avatar
Drives: 2011 RS
I have to ask, why can't you"read" the stick?? I check my oil level every week, always. Like CamaroFred said,"In case there is a leak". Mind Blown!
Eddiefuzz is offline   Reply With Quote
Old 06-18-2019, 08:35 PM   #7
rich2342
rich2342's Avatar
Does anyone have a picture of the ss stick. Where are the readings? There are 5 dots on the back of the stick. I believe mine is not reading on the top two after 1k. 2qts low, yes or no?
Old 06-19-2019, 08:54 AM   #8
ChibiBlackSheep
ChibiBlackSheep's Avatar
Drives: 2012 2SS/RS, 1968 SS
Turn the stick around. Those 5 dots are impressions on the other side. Your car should have oil SOMEWHERE within that range of dots.
If the dipstick is dry it is over 1 quart low. Add 1 quart, wait 5 minutes, check the dipstick again. If it's still dry add another quart.
You just need a defined oil line somewhere within the 5 dots.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS
ChibiBlackSheep is offline   Reply With Quote
Old 06-23-2019, 08:05 AM   #9
hunter1660
hunter1660's Avatar
Drives: 2011ss/rs camaro
If it's using that much oil,there should be a puddle under it or blue smoke fogging out the exhaust...my bet is it only had 5 qts. Added at time of change.
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
hunter1660 is offline   Reply With Quote
Old 06-23-2019, 08:55 AM   #10
rich2342
rich2342's Avatar
I verified with the service manager to see what came out, and obviously to fill to capacity. He spoke with the tech, 5 came out but, that oil was from an independant shop and I verified 8 were added.
Old 06-24-2019, 04:46 AM   #11
polizzio
polizzio's Avatar
Drives: 2012 1LT SIM Camaro
+1 here.
polizzio is offline   Reply With Quote
Old 06-24-2019, 08:17 AM   #12
Stingr69
'69 Owned Since '79
Stingr69's Avatar
This.
The tech only put 5 quarts in at the last oil change.
Add oil, check the dipstick and drive it for another 3500 miles and see what the dipstick shows. I bet it will be fine.
Old 10-02-2019, 11:01 PM   #13
songsj
Drives: 2015 2SS/RS Summit White
My money is also on only 5 went in.
songsj is offline   Reply With Quote
Old 10-03-2019, 05:09 AM   #14
Reichler
Reichler's Avatar
Drives: 2004 GTO & 2005 GTO
How exactly did you verify 8 qts were added? By a receipt? If so, no, that’s not verifying. Never, EVER, let someone else change your oil without immediately checking the level after they are done. If you didn’t, and drove 3k miles, then either they didn’t add the correct amount of oil or your engine is burning/leaking it.
Reichler is offline   Reply With Quote
