Old 05-26-2019, 03:12 AM   #1
weSS1LEy
weSS1LEy
weSS1LEy's Avatar
Drives: 2015 camaro 2ss/rs/1le
New cam driving experience
It’s been a week with my new cam. Car has good power, sounds great.
1- it hunts for idle in first 20-30 seconds then seems to settle. Is this normal?
2- during highway cruise with little throttle input there is slight bucking even above 2000 rpm. In fact 6th is better under 2000 than 4th or 5th is above 2000. It’s not bad and if this is normal then I can live with it. If it’s not though it may need some tweaking.
3- idle was set to 900 but when driving and warm, the car still idles down to 600 at stop lights.
4- car requires more clutch and throttle in my driveway and parking lots. This I am sure is just the nature of a large (ish) cam
Overall very happy but not sure if any of you cammed guys let service shops drive your cars anymore lol
Rotofab, arh no cats, atak, elite cc, 94 octane tune, Mobil 1, phastek scoop, custom cam 230/243 .621 .604 114+4, related cam kit stuff. 470/435 rwhp/rwtq
weSS1LEy is offline   Reply With Quote
Old 05-26-2019, 03:22 AM   #2
pnwdan
pnwdan's Avatar
Drives: 2014 2SS/RS
What cam did you go with?
My TSP stage 3 does not hunt at idle.That doesn't seem right. Also, my idle is set at 950 and that's where it stays.
Above 2k it should be smooth too.
Low rpm stop and go like in a parking lot is going to tedious because the cam moves the power range of the engine up so that sounds about right.
Sent from my SM-N960U using Tapatalk
2014 2SS/RS LS3/M6
pnwdan is offline   Reply With Quote
Old 05-26-2019, 04:34 AM   #3
weSS1LEy
weSS1LEy
weSS1LEy's Avatar
Custom cam in my sig. I should clarify it only hunts first 20 sec on initial first start/ cold start. Not long
Old 05-26-2019, 08:06 AM   #4
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
A larger cam will always do some of that but it sounds excessive. I don't think its tuned right. They got the WOT tune good but the rest needs work.
2015 1LE, TSP 225/236 113+3, VMAX Throttle Body, CAI with race scoop, GPI Ported Intake, Land Speed Stage 2 Heads, 1-7/8 headers, NPP exhaust, 25% Fluidampr, LT1-S Monster Clutch, 485 RWHP & 444 TQ
zz430camaro is offline   Reply With Quote
Old 05-26-2019, 09:32 AM   #5
sixty9fordkiller
Donkey Dick Cam Camaro
sixty9fordkiller's Avatar
Drives: 2010 2SS/RS LS3 M6
i cant see your sig but it sounds like its needs a little bit more tuning
it might be a stupid question but is your check engine like on?
Sent from my SM-G975U using Tapatalk
Bone Stock
sixty9fordkiller is offline   Reply With Quote
Old 05-26-2019, 09:44 AM   #6
PepeLePew
PepeLePew's Avatar
Drives: 2010 2SS Coupe; 2011 2LT Vert
Your tuner should be able to adjust for most of your concerns. Your cam is not that crazy and shouldn’t have bad manners with a good tune. Idle shouldn’t take long to find and it should bounce around +/-50 RPMs of where it is set. When cruising, you should be fine with no bucking with the RPMs about 1,500-1,600 RPMs (although under light load it might kick a little). Above 2,000 you should be smooth sailing. It makes me think you have a misfire if you are experience a buck above 2,000. I wonder if you have a plug fouled up.
2010 2SS/RS LS3 - K&N, GM Performance Axle Back, Hurst Shifter, TSP 1 7/8ths long tubes no cats, TSP Stage 2 "Bald Eagle" cam, GM 3.91, 466whp/429tq
PepeLePew is offline   Reply With Quote
Old 05-26-2019, 11:19 AM   #7
weSS1LEy
weSS1LEy
weSS1LEy's Avatar
No check engine light. I was thinking misfire too but I think that it would feel worse? It’s subtle at cruise. Like a little thump every 3 seconds or so. Goes away with more throttle.
Cam is 230/243 .620 .604 , 114+4 custom cam motion
Old 05-26-2019, 02:13 PM   #8
Badfinger
Badfinger's Avatar
Drives: 2010 2SS
Why don't you make a video so we can hear it? My car will idle a little high at cold start but comes down pretty quick and then goes in and out of a cadence.
Here's a video:
Badfinger is offline   Reply With Quote
Old 05-26-2019, 04:58 PM   #9
zlathim
zlathim's Avatar
Drives: 2010 Camaro 2SS/RS M6
Have you talked to your tuner? Dyno tune or remote?
GPI SS2; EE E2 catch can; SP 1 7/8" LT Headers w/ hfc; FM AT 3" cat-back; CAI Cold Air Intake; AEM Wideband
Tuned by GPI
McCleod RXT; MGW flat stick; Ram Clutch slave cylinder & hydraulic adjuster
BMR cradle & diff bushings, trailing arms, toe rods & upper control arm bushings
Hotchkis sub-frame brace
Stop Tech Z-23 brakes
4.10 gears, Eaton Truetrac, LPW diff cover
Best 1/4 mile 12.073 @ 115.68 mph 3,300 ft DA
zlathim is offline   Reply With Quote
Old 05-26-2019, 06:49 PM   #10
weSS1LEy
weSS1LEy
weSS1LEy's Avatar
Here's a video:
Good idea! Your car car sounds great!
Old 05-26-2019, 06:53 PM   #11
zz430camaro
Drives: 2015 1LE
It really pisses me off when these place screw up the tuning. What a pain in the ass for the customer.
Old 05-26-2019, 10:04 PM   #12
weSS1LEy
weSS1LEy
weSS1LEy's Avatar
I don’t know that anything is actually screwed up. It’s subtle stuff like at cruise and the idle gets to 900 on cold start but at warm driving it idles at 600-650. But even that is not too bad.
Old 05-26-2019, 10:14 PM   #13
zlathim
zlathim's Avatar
"hunting for idle" for 20-30 seconds isn't normal. The other things you mentioned sound like they are tune related to me. Trust me, I had many of the same issues. Your tune needs refined. That's why I asked if you have talked to your tuner.
Tuned by GPI
Old 05-26-2019, 10:54 PM   #14
weSS1LEy
weSS1LEy
weSS1LEy's Avatar
I haven’t talked to them yet, I wanted forum feedback in case it was all normal stuff. I’ll email them soon
